Motor Mounts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swimmerboy2112, Jun 20, 2013.
  1. Jun 20, 2013 at 7:26 AM
    Swimmerboy2112
    Swimmerboy2112 [OP] Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    I did some searching and can't seem to find anyone who makes poly motor/trans mounts for the 1st gen Tacos (i'm a V6). I don't really want to go with solid mounts due to the fact that they translate a lot of vibration and harshness into the cab.
    If anyone has any info on where I could purchase a set of poly motor/trans mounts that would be great!
    Thank you,
    -Brian
  2. Jun 20, 2013 at 7:29 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
  3. Jun 20, 2013 at 7:33 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Yes I've seen those, they are the solid mounts I was talking about. I'm just worried about all the motor vibrations being transferred into the cab.
  4. Jun 20, 2013 at 7:38 AM
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
  5. Jun 20, 2013 at 7:40 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Solid mounting the transmission and leaving the motor mounts rubber is a recipe for destroying the engine mounts.
    You either solid mount everything, or nothing.
  6. Jun 20, 2013 at 7:42 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Thank you for that link I did not know 4xI made mounts.
    I have heard this before, glad someone else can confirm this.
  7. Jun 20, 2013 at 7:44 AM
    steezemcqueen
    Dylan
    Crawlarado
    Not sure if you were responding to me but the 4xI mount isn't solid. Its poly.
  8. Jun 20, 2013 at 7:48 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yes I was responding to you, and yes it's a solid mount. I own it along with the TG mounts.
    Just because it has two thin poly bushings doesn't mean it's not a solid mount. A solid mount does not mean metal:metal. If you do strait metal to metal you'll rip the perches right off the frame. The poly on the 4x is just an isolater between the two pieces. The TG mounts are the same way, they have a poly bushing between the pivot points. They are still "solid mounts."
  9. Jun 20, 2013 at 8:08 AM
    steezemcqueen
    Dylan
    Crawlarado
    Umm...No. A solid motor mount is just that. Solid. Metal. No movement. The 4xI mount (which i own too) is a poly bushing which is stiffer than rubber but definitely not a solid mount. It moves too. I've also been running it with the stock motor mounts and they aren't destroyed....
  10. Jun 20, 2013 at 8:27 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    At the end of the day this is just terminology and nomenclature. The 4x mount moves...barely. Just as the TG mounts move...barely.
    So little that the feedback felt by the driver is enough to rattle your fillings out, which is what the OP doesn't want.
    My feedback comes from a desert racing perspective. And (semi) solid mounting half the drivetrain puts all the dampening on the non semi-solid mounting parts...which rips the rubber apart in spirited offroading. I can't speak for DD or mall crawling, but I started with only the 4x only and ended up with a torn engine mount on the torque side and a bent perch on the non-torque side. Carry on with whatever it is you want to do, just providing my input on what's happened on my truck.
  11. Jun 20, 2013 at 8:59 AM
    steezemcqueen
    Dylan
    Crawlarado
    That makes sense. My feedback comes from rock crawling and i haven't any issues with my setup. I can honestly say that the 4x mount didn't have a significant increase in stiffness but did help a lot with reducing the shifter movement side to side.
    Just providing my experiences like you were :cheers:
  12. Jun 20, 2013 at 10:36 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    I appreciate all the input guys, let's keep the advice coming!
  13. Jun 20, 2013 at 10:46 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    in my opinion, i dont see why u need to change the mounts....
    only reasons id change the nounts are if my rig was built like jasons flying through the desert w/ supercharged power catching air or....
    had a crawl box like dylan and waned mor support for the drivetrain. when i sas ill get all new mounts...
    until then stock works just fine imo
  14. Jun 20, 2013 at 1:54 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
    The stock mounts are starting to crack as the rubber is drying out. Also I will be installing my supercharger w/7th injector & 2.2" pulley in the coming month.
    Good to know, maybe I'll pick it up. If I don't like it, i'll just put the stock mount back in.
  15. Jun 20, 2013 at 11:55 PM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    How hard are they to install?
  16. Jun 21, 2013 at 5:01 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    It's a pretty simple, and straightforward, unbolt the old and bolt-on the new.
  17. Jun 21, 2013 at 6:58 AM
    Link817
    Link817 Member
    Auto or stick? I ordered poly mounts from lcengineering for the motor and did frontrange offroad transfercase mount. The whole drivetrain is now poly mounted, saving grace is that im a 5speed and dont get the vibrations sitting at a light. Only downside is that the stock mounts have a kinda heat cover to them that keeps the exhaust heat away, so one of my mounts has heat exposure to it. I dont know if the v6 exhuast is the same
  18. Jun 21, 2013 at 8:08 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    I'm a 5 speed. I couldn't find the poly mounts on LC Engineering's site, maybe i'm looking in the wrong spot? All I could find is the solid "bomb proof" mounts.
    I will check out Front Range Offroad though.
  19. Jun 21, 2013 at 12:01 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
  20. Jun 21, 2013 at 2:56 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Called LC Engineering today. They do not offer, nor do they know of anyone who makes poly mounts for the 5VZ-FE Tacoma... bummer. All they had to offer were solid mounts, but they said that if this truck is driven on the road ever (which it is) then I DO NOT want the solid mounts, which I already knew.
    Still, i'm not giving up on my search.
