Motor mounts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Billrunnels90813, May 22, 2025.
  1. May 22, 2025 at 8:04 PM
    Billrunnels90813
    Billrunnels90813 [OP] New Member
    Robert
    03 Tacoma 4X4
    Any advice on changing the motor mounts
  2. May 22, 2025 at 8:40 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Do one side at a time, and you can use a jack (with rubber padding) on the oil pan to create some space to replace the mounts.
    I installed the Solid Offroad motor mounts and absolutely love the way it cleaned up the sloppiness of the stock mounts.
    thomasburk likes this.
  3. May 22, 2025 at 9:03 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Also if you have the V6 your fan blades will want to catch on the shroud as you jack up the engine, so its helpful to have 2 people (one gently jacks it up, while the other gently prys the fan blades away from the shroud by hand to guide them up and past it).
    Black97v6MT and thomasburk like this.
  4. May 22, 2025 at 9:33 PM
    StreetSr5
    StreetSr5 Well-Known Member
    I did the motor mounts on my third gen and broke the fan shroud lol, you gotta unbolt the shroud and move it up a few inches or what you said works too
    Red_03Taco[QUOTED] likes this.
  5. May 22, 2025 at 9:45 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Don't forget there trans mount if you have a manual . There is some extra cab vibration while sitting and idling .
    Op I hope you have small hands.i did mine while my front diff was out it was still a pain in the dick.
  6. May 25, 2025 at 7:26 AM
    1997tacomav6
    Denver
    I replaced mine when doing my heads so was super easy at 800k, they actually were still in great shape and probably didn't need replacement
    TRD493 likes this.
