Motor oil filter change interval?
Discussion in '1st Gen. Tacomas (1995-2004)' started by chrispchicken9, Mar 16, 2019.
  1. Mar 23, 2019 at 3:24 PM
    #81
    tony2018
    tony2018 Well-Known Member
    every oil change, if you change your oil at 3k change the filter, if you change at 6k change the filter, if you change the oil at 53k change the filter.
    RysiuM likes this.
  2. Mar 23, 2019 at 5:55 PM
    #82
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Sure thing. I bought a box of OEM v8 filters to cover my GX and my Taco.
  3. Mar 23, 2019 at 6:27 PM
    #83
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Whatever you do, just make sure you tighten the stupid thing properly. I've learned my lesson from tightening it with a wrench, and just last week learned my lesson from not tightening it enough. It came loose after 3k miles. made a huge mess. Hand tight until I cant go anymore is how I'm gonna do it from now on. None of the 1/2 turn after the gasket touches crap, not tight enuff.
    underaroof and cruiserguy like this.
  4. Mar 23, 2019 at 9:02 PM
    #84
    tony2018
    its a no brainer...
  5. Mar 24, 2019 at 2:26 AM
    #85
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Actually FSM specifies 3/4 turn after touching (or specific torque ) is full hand tight (I couldn't turn more than 3/4 turn with hand). Fresh experience from oil change yesterday.
  6. Mar 24, 2019 at 2:28 AM
    #86
    tony2018
    i would also add to this that I add oil to the rubber seal too.
  7. Mar 24, 2019 at 4:15 AM
    #87
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Oem has grease on it already, only reason why i didnt mention it.
    cruiserguy likes this.
  8. Mar 24, 2019 at 4:56 AM
    #88
    RysiuM
    Rysiu
    I have not noticed that. My OEM filters have a foil over the top (I guess protecting from something falling inside) but the rubber like looking seal was not "wet".
    My filter part number is 90915-YZZD1
  9. Mar 24, 2019 at 5:14 AM
    #89
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yup thats the one. I get them with the foil cover but with a white vaseline type grease on the o ring.
    RysiuM[QUOTED] likes this.
  10. Mar 24, 2019 at 5:47 AM
    #90
    RysiuM
    Rysiu
    I guess you got better batch :thumbsup:
  11. Mar 24, 2019 at 5:48 AM
    #91
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Idk, I get them individually from my dealer. Theyve all been like that, even the ones for my sisters car.
  12. Mar 24, 2019 at 6:02 AM
    #92
    RysiuM
    Rysiu
    I just double checked the plastic film I removed from the filter. You are right, there is a trace of some vaseline like substance. But I never considered that as a substitute for oiling the seal. I was thinking this is for the rubber to not dry out. I am probably wrong and overprotective but it's just me.
    Another of "just me" example:
    Because local Nissan dealer sold me the wrong oil filter I had to put back the old one when I changed the oil in my wife's Versa Note. But this was so i could fill it with the new oil and drive of the ramps. I'm doing the partial oil change in my wife's Nissan next weekend again (drain whatever comes out to the filter level), this time with the new oil filter. I know 100% of you will say it's a waste of money but for me it is gaining a piece of mind.
  13. Mar 24, 2019 at 9:12 PM
    #93
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    I've done the same, not quite tightened it enough on an old Volvo 245 I had back in the day. A few weeks later I lost A LOT of oil...all over the driveway.
    Hand tight with some fresh oil on the gasket, feel free to crank it down with your hand, but don't use any tools to put it back on. This ensures you can get it back off with the help of a tool. I've had a hell of a time removing filters when people use a tool to put it on, it's just unnecessary.
  14. Mar 25, 2019 at 3:52 AM
    #94
    Brake Weight
    I put my filters on with my left hand as tight as I can get them. Then most every time I can get them off with my right hand, since I’m right handed.
  15. Mar 25, 2019 at 3:55 AM
    #95
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Wait. Y'all change the oil filter? I just put more oil in the 710 cap when it gets low.
  16. Mar 25, 2019 at 8:18 AM
    #96
    RysiuM
    Rysiu
    You are wasting money. You should have put water. Works as well as oil in that application.:rofl:
  17. Mar 25, 2019 at 8:58 AM
    #97
    Shiki Shabazz
    Shiki Shabazz Well-Known Member
    Tulsa, OK
    2003 Tacoma Dbl Cab TRD
    I've been using this for a while too. I never remove the skids.
  18. Mar 25, 2019 at 12:54 PM
    #98
    RysiuM
    Rysiu
    Then how do you access the valve and oil filter?:notsure:
  19. Mar 25, 2019 at 1:57 PM
    #99
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    there is a hole for the normal drain valve, about 6 inches in diameter thru the skid already. the Fumoto just allows you to attach a hose to make the point of contact almost directly in the pan
    and I access the filter thru the driver's side tire well
    not sure where the I4 is located, under passenger side?
    Shiki Shabazz likes this.
  20. Mar 25, 2019 at 1:58 PM
    #100
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    This thread is still going. OP ever decide to change his filter?
