motor or suspension ?
Discussion in '1st Gen. Builds (1995-2004)' started by mstoudt, Jul 31, 2012.
  1. Jul 31, 2012 at 3:39 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    04 tacoma SR5 Double cab
    3 inch suspension lift, 3 inch body lift, 285/75/16 dick cepek fun country II, tinted windows, K&N cold air intake, 16 inch KMC dx series wheels, flowmaster dual exhaust
    im itching to do something to improve my build.... do you guys think i should go with beefing up my motor or suspension? ill take any ideas,comments, just need some help.:D
  2. Jul 31, 2012 at 3:41 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    whats your plan for the truck?...
  3. Jul 31, 2012 at 3:42 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    ^^ what the top 2 said
  4. Jul 31, 2012 at 3:43 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    well obviously look nasty but daily driver and off road machine! pretty much best of both worlds. ha mud and trails
  5. Jul 31, 2012 at 3:44 PM
    97yota4wd
    Eric
    Mesa, AZ
    our engines already outrun our suspension, so i would go with suspension.
  6. Jul 31, 2012 at 3:44 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    mud?
    get a 4x4
  7. Jul 31, 2012 at 3:45 PM
    superswamper003
    Hendrik
    Yeah if you wheel alot then just get some nice coilovers or something like that
  8. Jul 31, 2012 at 3:45 PM
    97yota4wd
    Eric
    Mesa, AZ
    how do you know hes not 4x4?
  9. Jul 31, 2012 at 3:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    his description.
    edit: I guess your description doesn't specify :laugh:
    well if you have a prerunner OP, it won't do well in mud. Then again mud sucks so no big loss.
  10. Jul 31, 2012 at 3:47 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    what do ya think i should start out with to improve my suspension? and is there anything i can to for some extra power besides intake an exhaust ? thats not turbo or s/c?
  11. Jul 31, 2012 at 3:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    not really, you need to boost it to get noticeable power gains.
  12. Jul 31, 2012 at 3:50 PM
    superswamper003
    Hendrik
    Yep. You can get some headers, combined with a borla or something else with a k and N cold air intake.... And for supension, either go with a drop bracket lift which isnt recommended by most, or get some nice coilovers................ Or do an SAS :D
  13. Jul 31, 2012 at 3:51 PM
    superswamper003
    Hendrik
    but the headers only ad slight increase in power. not like a s/c or turbo does
  14. Jul 31, 2012 at 3:51 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    2004 Toyota Tacoma double cab sr5 4wd tow package v6 3.4
  15. Jul 31, 2012 at 3:52 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    the deck plate mod is a bit cheaper for similar gains;)
  16. Jul 31, 2012 at 3:53 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    UCA's will improve front end droop.
  17. Jul 31, 2012 at 3:53 PM
    superswamper003
    Hendrik
    Oh.. See i know nothing about that mod :eek:
  18. Jul 31, 2012 at 3:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    you cut a hole in the stock air box, done :laugh:
  19. Jul 31, 2012 at 3:55 PM
    97yota4wd
    Eric
    Mesa, AZ
    to start, you can get some coilovers. i suggest getting king/fox/icon. but i would also look into cheaper alternatives like SAW coilovers.
    make sure to get the ext travel ones.
    then after that you can upgrade to a uniball upper control arm.
    after that the possibilities are endless, you can start on the rear, or keep up with the front. it really depends on your budget and other things.
    some headers you will lose power in the lower RPM range.
    technically the tacomas have a stock cold air intake. you should do the deck plate mod instead.
    DO NOT GET A DROP BRACKET LIFT. :mad:
    doubt you will even want to think about a SAS. properly done is like 10k.
    i forget if you can do the deck plate on a 3.4..... but if so, do it!
  20. Jul 31, 2012 at 3:57 PM
    superswamper003
    Hendrik
    I learn something new every day.
