Motor shaking and sputtering
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bigcountry75, Oct 22, 2017.
  1. Oct 22, 2017 at 12:21 PM
    Bigcountry75
    Bigcountry75 [OP] Well-Known Member
    Bryan
    2004 Toyota Tacoma
    3' leveling kit 285/75r16 tires
    So I just took a trip in my truck to luray VA truck ran perfect on the way there was coming back took a stop for about 30min can put started the truck motor was jumping an shaking so bad it was shaking the hole truck shook even worse in gear when I went to take off it sputters really bad for about 15 mins of truck but then clears up but if I stop for awhile then go to drive again it comes back. Anyone know maybe got back gas with water in it. Have no clue what it could be! I have a video I could share of it if anyone wanted to help an know further details thank you
  2. Oct 22, 2017 at 4:59 PM
    yayayayayaya
    yayayayayaya Active Member
    Patrick
    Alaska
    1999 V6 Tacoma
    Keeping it tame
    That sounds like my truck when there are issues with the spark plugs or fuel injectors. Check engine light?
  3. Oct 23, 2017 at 1:03 AM
    Bigcountry75
    Bryan
    2004 Toyota Tacoma
    Yes check engine light but it was on before this happen for a evap system leak. I just changed spark plugs couple months ago put E3 spark plugs
  4. Oct 23, 2017 at 1:15 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Could be a vacuum leak - they tend to go away once the engine is warm like you mentioned. No way to say for sure without looking at it and running some tests. Ignition, air supply, or fuel problems could all cause that unfortunately.
  5. Oct 23, 2017 at 4:30 AM
    Bigcountry75
    Bryan
    2004 Toyota Tacoma
    Ugh that’s for all the help
  6. Oct 24, 2017 at 12:34 PM
    Bigcountry75
    Bryan
    2004 Toyota Tacoma
    So I got the code read it was cylinder 3 miss firing I changed the ignition coil 90$ later an it’s still doing it an just sitting here an can’t figure out what it is
  7. Oct 24, 2017 at 12:50 PM
    yayayayayaya
    Patrick
    Alaska
    1999 V6 Tacoma
    Keeping it tame
    My bet is a leaky fuel injector because you started the car while it was still warm then you started getting the problem. If it was a coil pack it would have been two cylinders I believe. I have the same exact problem right now
  8. Oct 24, 2017 at 1:58 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Depending on what motor you have, it could be oil leaking around the valve cover gasket and shorting out the spark plugs.
    yayayayayaya likes this.
  9. Oct 24, 2017 at 3:33 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Mine did the same at 160K miles. Same code. Replaced fuel injectors and issue went away. 2000 PreRunner 2.7L
  10. Oct 24, 2017 at 4:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can do a compression test on that bank of cylinders and find out if it's a mechanical cause for misfire in that cylinder if it's way below the other two. If it's not then it could be a plugged injector (or other things :)) You can use the screw driver test for the injector to see if it's misfiring.
  11. Oct 24, 2017 at 4:40 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Compression, spark, and fuel. Test In that order
  12. Oct 24, 2017 at 4:46 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Pulling the spark plug for a visual inspection wouldn't be a bad idea since it's a 15 minute job since it's on the passenger side and he already replaced the wire. Then compression and fuel for sure.
  13. Oct 27, 2017 at 8:29 PM
    yayayayayaya
    Patrick
    Alaska
    1999 V6 Tacoma
    Keeping it tame
    So I replaced my number 6 injector, and now running smoothly. Its funny the code reader at O'Rileys was saying both #3 and #6 were misfiring, which stumped me. Because the misfire didn't move when I rotated my coil packs.
    Did it in 3 hours :bananadance:
  14. Nov 2, 2017 at 6:36 AM
    Bigcountry75
    Bryan
    2004 Toyota Tacoma
    Thank you for the help because my code is reading the same exact thing!
