Motor Squealing
Discussion in '1st Gen. Tacomas (1995-2004)' started by xitsjacob, Feb 21, 2024.
  1. Feb 21, 2024 at 12:51 PM
    xitsjacob
    xitsjacob [OP] 98 2.4 Taco
    HTX
    Got belts tightened and checked
    Could it be the timing belt
    happens on start and low speeds
  2. Feb 21, 2024 at 12:54 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Probably the accessory belts. Mine is doing the same thing.
  3. Feb 21, 2024 at 1:12 PM
    perterra
    perterra Well-Known Member
    Tejas
    Timing belt is toothed. Likely an accessory belt. The tensioner went out on mine and it did the same.
    xitsjacob[OP] likes this.
  4. Feb 21, 2024 at 1:13 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    faulty T-chain on a 2.4L would be a much more horrible sound than a squeal
    pwr steering pump?
  5. Feb 21, 2024 at 5:28 PM
    Glamisman
    Glamisman Well-Known Member
  6. Feb 21, 2024 at 7:41 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    Squirt water on the ribbed side of the belt as it's running and it will immediately quiet if that's it. Tightening it doesn't help unless it was really really loose. They get damaged from coolant, grime, or the friction of slipping too many times if it was loose.
