Motor stumbles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by C4vettrn, Apr 15, 2022.
  1. Apr 15, 2022 at 8:06 AM
    C4vettrn
    C4vettrn [OP] Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    2020 with 35k on it. Motor has a slight miss or stumble around 1,200-1,500 rpm under a load. Doesn't happen all the time just occasionally and not throwing any codes. I can make it do it if rpm's and load is just right by lugging the engine. Any thoughts, anyone else had this issue ?
    JustJon likes this.
  2. Apr 15, 2022 at 8:24 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I'd use a good scanner to see if you can see any codes/potantial codes. Otherwise I'd check the plugs, I did mine at 40k and they were pretty nasty
    mquibble likes this.
  3. Apr 15, 2022 at 8:28 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Common problem when less than 1500rpm at 40-55mph. Feels like lugging a stick shift. Toyota says this is a normal characteristic...
    Chew and zoo truck like this.
  4. Apr 15, 2022 at 8:34 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I wouldn’t make that a habit. Bad for your engine. Going 91 octane should take care of that.
    cryptolime likes this.
  5. Apr 15, 2022 at 8:36 AM
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    Despite being a truck, these engines are meant to be rev'd out a bit.
    Chew likes this.
  6. Apr 15, 2022 at 8:44 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yup a buddies 2019 trd always did the same at 1300 rpm when using 6th gear. Its weird some trucks will do it while others won't. I can't make my truck do it...at least not yet. Seems some 3.5's make a little more power than others that overrides this issue, either that or the transmissions just work better....maybe a little of both..
  7. Apr 15, 2022 at 9:05 AM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Doesn't make sense it didn't do it untill this spring. Something had to of changed.
  8. Apr 15, 2022 at 9:08 AM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Which tune did you get and how much did it cost ?
  9. Apr 17, 2022 at 9:01 AM
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    Sooo, last night leaving the hockey game about 40°. I started the Taco put it in gear and left. No warm up time. As soon as we got out of the parking lot after I hit 3rd gear. Lugging it a little 1500ish rpm, it had a really bad miss fire/stumble/cut out. Only did it once but it did it bad enough my wife noticed in the passenger seat. Only has 700 miles on it and is OV tuned by my buddy @tonered.
    tonered likes this.
  10. Apr 17, 2022 at 10:25 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Did anyone notice he has a 2nd gen Tacoma with the 4.0?
    Otterstuff and Junkhead like this.
  11. Apr 17, 2022 at 11:03 AM
    zoo truck
    None
    Just curious what trim the trucks are. Buddies was a trd, i've heard every trd will do it when i spoke to my buddy...its normal.
  12. Apr 17, 2022 at 11:10 AM
    zoo truck
    None
    I'd say at $350 per tune, it better make the truck run like a modern v8 otherwise your getting hosed.
  13. Apr 17, 2022 at 11:13 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    actually, the change in weather conditions can trigger knock sensors which may take some time for the ECU to adjust to the new conditions. i found that the ecu starts to retard timing on 87 octane once the weather starts to get warm. i usually run 89-91 octane in the summer for this reason. although, with gas prices, i may just accept the slight loss in power.
  14. Apr 17, 2022 at 11:20 AM
    TACO-TY
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    Post says 2020 with 35K...
    hiPSI[QUOTED] likes this.
  15. Apr 17, 2022 at 11:45 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Signature says otherwise.
    The plot thickens.
  16. Apr 17, 2022 at 11:46 AM
    TACO-TY
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    Posted in the 3rd gen forum. Your move:rofl:
  17. Apr 17, 2022 at 11:52 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol his profile pic is 2nd gen.:duel:
    :spy:
    TACO-TY[QUOTED] likes this.
  18. Apr 17, 2022 at 11:53 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  19. Apr 17, 2022 at 11:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't lug the engine is thought 1.
  20. Apr 17, 2022 at 11:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Some folks don't care about or know how to update their profile info.
    That's my gambit in this game. :p
    TACO-TY and hiPSI[QUOTED] like this.
