Motor Swap question ????
Discussion in 'Technical Chat' started by z71bowhunter, Dec 24, 2012.
  1. Dec 24, 2012 at 7:23 PM
    z71bowhunter
    z71bowhunter [OP] Well-Known Member
    Randy
    Temple,Ga
    96 Tacoma Ex-Cab 4x4
    I just purchased a 1996 Tacoma 4x4 auto 2.7liter.Just curious what I would have to change to put the 6cyl in this? Will the transmission bolt up???
  2. Dec 30, 2012 at 10:53 AM
    BamaToy1997
    Bill
    Navarre, FL
    The transmission I believe has a different bolt pattern between the two. As for changing the engines out, you have a bit of work ahead of you. you will need the ECM, as well as the wiring harness for the swap. It can be done though!
  3. Dec 30, 2012 at 11:06 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It shouldn't be too difficult to find a cheap rusted out V6 truck for your swap.
  4. Dec 30, 2012 at 11:13 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    far cheaper and easier to rebuild the motor...and IIRC folks sell better heads to up the power. On the other hand, a simple rebuild of the motor might give you the power you want.
    After 27 years, the motor is probably getting a bit tired.
    And I have had good luck in getting a local shop to rebuild my engines if they are running when pulled.
    Howard
  5. Dec 31, 2012 at 11:50 AM
    BamaToy1997
    Bill
    Navarre, FL
    27 years? It's a 1996 model, not a 1985...lol
  6. Dec 31, 2012 at 12:57 PM
    hetkind
    Howard
    Johnson City
    Ok, motors can get tired in 16 years also...sorry about my math, see my post under favorite whiskey...
    Howard
  7. Dec 31, 2012 at 1:05 PM
    MJM777
    MJM777 Well-Known Member
    N.E. Ohio
    2012 DCSB 4x4 Sport
    LOL......Cheers :cheers:
  8. Jan 1, 2013 at 6:16 PM
    BamaToy1997
    Bill
    Navarre, FL
    Hence my "lol" at the end. I knew you had to have just done the math wrong. Yes, some motors can get tired in 16 years, but I have seen more and more engines running well into the 200k plus range, and 20 years. But yes, you are correct.
