Motor Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timofthehill, Feb 26, 2012.
  1. Feb 26, 2012 at 5:31 PM
    timofthehill
    timofthehill [OP] Timmy
    Timmy
    Caledon Ontario
    06 Prerunner SR5 TRD Debadged
    7" Suspension Lift, 3" Body Lift, 33's on 17's, K&N Intake, Magnaflow Cat-Back Exhaust
    Hello everyone,
    I was wondering what I would have to do to swap out the 4.0 to put in the 4.7 motor in my 06 Tacoma. I think in 05 they had that motor in the 4-Runners. I want more power. I love the truck and there ain't much out there for the Taco's 4.0 which sucks. I have the Magnaflow exhaust, K&N CAI and URD Maf Cal, which I should have got the unichip or the X-1. But I think I may want to put the V8 in it. Let me know what you think and if you have any info.
    Thanks
  2. Feb 26, 2012 at 5:36 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    The 4.7 has a timing belt.Go for the 4.6 because it has a timing chain or just put on a turbo.
  3. Feb 26, 2012 at 5:42 PM
    timofthehill
    Timmy
    Caledon Ontario
    Turbo or sugercharger would be more costly then the motor swap. after you install the turbo/supercharger you gotta get it tuned. I want it to pull harder when I get into without changing my gear ratio
  4. Feb 26, 2012 at 5:43 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It would be easier and cheaper to get a supercharger.
  5. Feb 26, 2012 at 5:48 PM
    dexterdog
    Oly WA
    2012 F150
    Initial costs maybe but all of the fab and electrical work would easily surpass the cost of a supercharger.
  6. Feb 26, 2012 at 5:48 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    No.
  7. Feb 26, 2012 at 5:56 PM
    timofthehill
    Timmy
    Caledon Ontario
    Long Tube headers, will they screw up my emissions testing up here in Canada? The truck shouldn't fail with just 2 cats?
  8. Feb 26, 2012 at 7:03 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    The truck will not fail on two cats if you purchase an O2 sensor simulator along with your headers.
    And unless you plan on doing the swap by yourself, you can plan on spending way more than a supercharger with a tune.
    If you're going to do a swap just do the 5.7 and replace the whole powertrain.
  9. Feb 26, 2012 at 7:14 PM
    timofthehill
    Timmy
    Caledon Ontario
    what do you think about this Intake spacer product? I just saw it. Maybe put that on with unichips headers and programmer?
  10. Feb 26, 2012 at 7:16 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    Maybe you could just buy an older mid-size tundra with a v-8
  11. Feb 26, 2012 at 7:20 PM
    timofthehill
    Timmy
    Caledon Ontario
    ya I could, but it there is ways to make that 4.0 really perform, then I'm all for it. its a great motor. My truck has gone to hell in back. with it lifted and all I took it through everything I came across.
  12. Feb 26, 2012 at 7:20 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Well everyone is hoping and waiting for confirmed gains down low in the RPM range.
    Unichips blow. Get the ECU-3 from URD or the programmer they are running with their superchargers now (I forget the name).
  13. Feb 26, 2012 at 7:32 PM
    timofthehill
    Timmy
    Caledon Ontario
    I have that Maf Cal from them, but I'm not to happy about it. I wish it was as good as everyone talks about it. keep me info about that inatake spacer. I was told throttle body spacers don't do much at all.
  14. Feb 26, 2012 at 7:32 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Wyatt (if you don't know who Wyatt is, GTFO:p) is swapping in the 4.7 into the Beast currently so I'd contact him & see what he says, if you're serious about doing it :cool:
