MOTOR SWAP
Discussion in 'Toyota Trucks & SUVs' started by CRC65, Oct 25, 2012.
  1. Oct 25, 2012 at 1:04 PM
    CRC65
    CRC65 [OP] New Member
    CLAY
    COLORADO
    07 TACO
    3IN LIFT,GRILL GAURD AND WINCH
    I PUT A 4.0 OUT OF A O8 FJ INTO MY 07 TACOMA EVERYTHING PLUGGED IN BUT NOW MY VVT NOT WORKING ANYONE HAVE ANY IDEAS
  2. Nov 26, 2012 at 1:47 AM
    RussellG
    RussellG Well-Known Member
    Russell
    Firestone
    87 DLX/00taco everything except the FJ bits
    Diamond Axle SAS, TRD FJ calipers and brembo rotors on all 4, FJ rear axle, 5.29's and elockers in both, 3rz swap and dual cases,4.7 rear case,00 taco dash, bobbed bed,soft topper,raceline beadlocks, fj cruiser steering wheel and clinometer, super white paint and 37'' kevlars. Much more but i will keep it simple.
    What harness did you use? If you just plugged in the Fj engine harness to the taco ecu then you could have something as stupid as 1 wire be differet. I don't have both diagrams in front of me but I'd say you should have put your wiring on the Fj motor and used your acc stuff to insure no issues.
