Motor swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaqueen, Dec 8, 2024.
  1. Dec 8, 2024 at 8:44 AM
    Tacomaqueen
    Tacomaqueen [OP] Member
    Sueann
    2005 tacoma pre runner
    Will a 1999 tacoma work with a 2005 tacoma both are 2.7l??
  2. Dec 8, 2024 at 11:31 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Everything is gonna work completely differently....
    thottle body, ecm, tranny,.....list goes on
    Even the fuel pump is controlled differently.....older one's ecm interrupts to ground to control it, and newer ones use the positive side in the open control circuit...
    So quite an undertaking
    The engines are readily available for either.....would not make sense...
    unless you're just after a 1- or 2-year project....
    That 3rz engine is like a jeep legion product......those and the parts for em will be available ......forever......
    They used the 3rz in so many base models its ridiculous...
    MOst either go low and risk a JDM used engine.....
    or go high and get a rebuilt one with warranty...up to 7yrs
    Remanufactured Engines - Toyota - 2.7L - Powertrain Products
    Toyota only bare empty block BLOCK Truck Tacoma 3RZ Pickup 4runner 4x4 3RZFE | eBay
    And I bought a 2rz(2,4l) small block from these guys 5 yrs ago
    https://www.ebay.com/itm/305677637827
    I've even seen brandnew crated ones on Facebook market before
    Tacomaqueen[OP] likes this.
  3. Dec 8, 2024 at 12:17 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    The first gen (1995-2004) Tacoma 2.7 is a 3RZ-FE. The second gen (2005-2015) 2.7 is a 2TR-FE. They're distant cousins, and entirely different engines as far as a swap is concerned.
    Possible? Technically yes, with a lot of work by a skilled/talented individual. Practical? Absolutely not.
  4. Dec 8, 2024 at 12:24 PM
    O'Silver_Taco
    MD
    3Rz(2,7) are readily available....
    the later ones 2TR's had ring problems are in higher demand.....but much lower supply...
    using one of them you risk getting an oil burner....
    IF you have 2TR, its probably safest to go factory crate .......still make em
  5. Dec 9, 2024 at 12:34 PM
    Tacomaqueen
    Sueann
    Thanks I have the 2005 a mechanic destroyed the engine and said oops can't fix it. But a friend said he had a 1999 rebuild from a machine shop. But no I am not looking for a project that's a complete mess. Thanks for the response
  6. Dec 9, 2024 at 12:52 PM
    O'Silver_Taco
    MD
    Again something that new......toyota still makes/sells every single piece....
    they just cant sell you the whole long block........only short blocks and heads
    these can have the ring problem......so make sure you get some kind of warranty
    these you can do a national search and find a low mileage salvage one.....
    ......but you'd risk getting one of the older ones with bad rings...
    new crated one is safest way.......probably mid 4000's for it with all the gaskets, ect.....plus ship
    Carcarenut does a video on this exact swap out
    https://www.youtube.com/watch?v=WOcA6Dp8ZJQ&t=2s
