motor vacum issue help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tailzz, Apr 27, 2016.
  1. Apr 27, 2016 at 5:28 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    2000 tacoma trd prerunner 2d
    Bilstein 5150 front adjustable shocks set at 2 1/2 inc on 31×10.50 goodyear wranglers
    Im hearing a constant tick from around the driver side brake master cylinder, it sounds like a vacum but not srue. Just curious if this is a common issue in 2000 tacoma 3.4 pre runner. 164,000 everything runs great except for this tick noise,dosent sound like it is coming nfrom motor,more like firwall area around master cylinder any info would be great thanks
  2. Apr 27, 2016 at 5:39 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    Sounds like a vacuum leak. Might want to start with brake vacuum booster.
  3. Apr 27, 2016 at 7:43 PM
    sypher651
    sypher651 Nothin' but trail lovin'!!
    Groveland, California
    1996 Tacoma 4x4 3rz
    So I have the same thing happening to mine, I have been told that it is the vacuum purge valve, and you are just hearing it working. I get the same sound but it goes away more so when you accelerate. But what do I know I have a 96 3rz, but it is not causing problems.
  4. Apr 27, 2016 at 8:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It could be an exhaust leak....
  5. Apr 27, 2016 at 8:42 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    Thanks for reply's, your right i dont think its causeing any problems that i know of. Just super annoying. Here it at idle the worse.
