Motorcycle Carriers
Discussion in 'Towing' started by NumNutz, Oct 13, 2010.
  1. Oct 13, 2010 at 8:35 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    So I'm in the market for a motorcycle carrier. I don't really want to buy a whole trailer so I was thinking one of the trailer hitch motorcycle carriers would work?
    Anyone have any opinions on them?
    http://www.discountramps.com/smc-600-motorcycle-hauler.htm
    Bike is 415lbs.
    Rack is 100lbs.
    So it looks like it will be under the 650lbs. tongue weight rating for the truck but is the rating I'm suppose to be looking at?
  2. Oct 13, 2010 at 8:43 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Probably will make your truck sag a bunch because of how far weight is off the hitch.
  3. Oct 13, 2010 at 8:47 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    x2 if i had a hitch id probably make one. If id do it id want the bike to site closer to the tail gate and put the ramp further back. Opposite of the picture
  4. Oct 13, 2010 at 9:00 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    those things have always seemed really weak to me
  5. Oct 14, 2010 at 11:23 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Bump. Anymore ideas.
  6. Oct 14, 2010 at 11:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't want that much weight that far behind the bumper. Seems like it'd sag and sway horribly. There are foldable trailers also, I know you said you didn't want one but the folding ones don't take much room when stowed.
    If you're only hauling one bike, why not just use the pick-up?
  7. Oct 14, 2010 at 11:59 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    It's pretty hard to load and unload with a ramp isn't it? I'm a pretty small guy.
  8. Oct 14, 2010 at 12:02 PM
    toytacoma22
    toytacoma22 Well-Known Member
    COS
    3" Icon Lift, TC UCA, OME Dakars, Allpro front and rear bumpers.
    My dad uses one on his 08 4runner it works just fine. I would buy one to haul my bike around.
  9. Oct 14, 2010 at 12:02 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Not to mention they seem really expensive.
  10. Oct 14, 2010 at 12:09 PM
    BarkSlayer
    BarkSlayer Well-Known Member
    Jim
    Northwest Ohio
    Silver SR5 with 2.7 liter 5-speed stick
    Bed-Buddy motorcycle tie-down bar installed in headwall.
    I had one back in the early nineties - factory built from virgin Canadian steel, and my bike only weighed 235 lbs. The unit itself was so heavy, it took four men and a boy to carry it. I never trusted the thing and with all the weight back there, it made my vehicle handle weird. I'd say only if you must, otherwise, get yourself a nice, wide aluminum ATV ramp and run it up into the bed. With 400+ lbs. there, everything works as it should.
  11. Oct 14, 2010 at 12:09 PM
    PatSully
    PatSully Well-Known Member
    Pat
    Phoenix
    07 Access Cab TRD O/R
    Rear AAL, Extra D-Rings
    i use a 3 fold ramp from harbor freight, its ok and i can ride my bike up into the bed and roll it back off by myself. the front wheel slides a bit on the plastic bed, but i can modulate that.
    another way to make is easier is to have 2 ramps, one to walk on and another for the bike to roll on. thats what i used to o with my buddy's truck before i had my own.
  12. Oct 14, 2010 at 12:11 PM
    Pugga
    Massachusetts
    Nope, I do it with my bike all the time and I'm not overly large (5' 9" 170lb and my bike weighs 450ish, it's a Katana 750). If you can find a ditch to back into so the climb up the ramp isn't as bad, or even a level drive in, it helps tremendously. Even backing up to a curb to pick up 6 inches helps out. I have a set of the folding aluminum ramps. You just need 2 ramps, one for the bike, one for you and you walk beside it and feather the clutch and walk it up the ramp. If you're nervous about it, have a spotter the first time. If you're really really nervous about it, you're probably better off finding another solution like the hitch mount or a trailer.
  13. Oct 14, 2010 at 1:07 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I wouldn't be apposed to getting a ramp but just nervous about falling with it. Spotter isn't a bad idea.
    I'd want a really easy to use I guess. Like this one is pretty cool and seems easy but expensive as hell.
    http://www.discountramps.com/motorcycle_ramps.htm
  14. Oct 14, 2010 at 1:19 PM
    Pugga
    Massachusetts
    That looks like it'd be a pain to haul around with the motorcycle in the bed. I like the folding ones because they're light weight and fold down small so you can put them in the bed of the truck along with the motorcycle.
    As far as getting a bike on the back of a pick-up with ramps, take your time, let the bike do the work, this takes an even hand on the clutch and make sure you warm up the engine because you don't want it to stall on the ramps. Line it up, I usually run it up the ramp a foot or two to make sure the line I'm on is correct, then back it down and go for it. Keep the RPM's constant (about 1/3-1/2 throttle depending on the bike, about 1/2 for your sport bike) and vary the power and speed with the clutch. If you find a ditch, hill or curb to back up to, you can cut down the angle so it's almost no incline for a ramp at all.
    When you take it off the truck, use the front brake while you back it off. You don't want the tire to lose traction and skid so use the brake to slow it down, don't attempt to stop it on the ramp. Make sure you have plenty of room behind the truck so you can roll it off the ramp and still have 5 - 6 foot for it to roll without hitting anything.
    I make a chock for the front tire for my truck out of random 2x4's I had sitting around. The front wall on the composite box isn't very stiff and allows the bike tire to turn. I transport the bike straight in the box, I don't angle it like some people here. I have a short bed so angling still will not allow me to close the tail gate, and angling makes it harder to load/unload vs straight in, straight out.
  15. Oct 14, 2010 at 1:40 PM
    NumNutz
    Virginia Beach, VA
    Lots.
  16. Oct 14, 2010 at 1:59 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dude i have used one for many years with my dirt bike and one for a few years that held my quad.....
    your truck will sag a bit but it is well worth the convience
    i loved it ....it worked amazing......
    g/l
  17. Oct 14, 2010 at 2:01 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  18. Oct 14, 2010 at 2:08 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    So what about a motorcycle ramp and a Timbren kit to take control of the sagging?
  19. Oct 14, 2010 at 2:10 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i wouldnt worry about the timbren kit just yet...
    its not like you are gonna drive around with it hangin off the back all the time just occasional i assume...
    just dont drive it like a sports car......
  20. Oct 14, 2010 at 2:11 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    oh mine cam with the ramp right on the bike carrier.... it was sweet and easy
    lazy man bike carrier
