Motorcycle Chock for Bed Rail System?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RZRob, Feb 27, 2011.
  1. Feb 27, 2011 at 9:21 PM
    RZRob
    RZRob [OP] Well-Known Member
    Robert
    Anaheim Hills
    We take a couple dirt bikes every weekend in my friend's Tacoma and it seems we're always stopping to straighten the wheel of one of them.
    Doesn't somebody make a chock for the factory bed rail?
    It doesn't seem like a tall order. I don't want to have to ask my buddy to drill any holes etc., that's why I'd think somebody makes this, but I can't seem to find anything.
    HELP!!!
    RZ Rob
  2. Feb 27, 2011 at 9:26 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Where there's a will, there's a way!
  3. Feb 27, 2011 at 9:32 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i have to find it... there is something exactly what you describe here somewhere
  4. Feb 27, 2011 at 9:33 PM
    Yoytoda
    Roland
    completely stock
  5. Feb 27, 2011 at 9:44 PM
    RZRob
    Robert
    Anaheim Hills
    Wow guys, thanks for the quick responses. I looked at these and conceptually really like them, but do these attach to the stock bedrail system? I assume these require drilling? Seems like there may be availability issues too.
    RZ Rob
  6. Feb 27, 2011 at 9:46 PM
    SMTRDSPORT
    SMTRDSPORT Member
    Eric
  7. Feb 27, 2011 at 9:51 PM
    Yoytoda
    Roland
    completely stock
    you can make them attach to the stock rail system. it would take a little ingenuity but very possible. I would take a piece of 1/2" (or whatever the width of the rail) 3/16" thick flat bar. cut 2" long pieces and drill and tap them and slide them into the rail for mounting
  8. Feb 27, 2011 at 9:51 PM
    RZRob
    Robert
    Anaheim Hills
  9. Feb 27, 2011 at 9:53 PM
    Yoytoda
    Roland
    completely stock
    i could probably fab up something that fits in the bed and is held in place by the weight of the bike and holds the tire straight...
  10. Feb 27, 2011 at 9:56 PM
    RZRob
    Robert
    Anaheim Hills
    I totally get it. I'm going to study this, considering what Ryan's saying too about the vertical placement.
    RZ Rob
  11. Feb 27, 2011 at 10:00 PM
    RZRob
    Robert
    Anaheim Hills
    I may hit you up if I can't find something off the shelf. Thanks
    RZ Rob
  12. Feb 27, 2011 at 10:25 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    I stuff my bike in the corner and doesnt move. Use two straps to the front hooks like normal and one attached to either side to the middle hook. I wish I had a pic but the third strap is the key to it turning.
  13. Feb 27, 2011 at 10:34 PM
    Yoytoda
    Roland
    completely stock
  14. Feb 27, 2011 at 10:42 PM
    Yoytoda
    Roland
    completely stock
    yea, i just use a piece of 2x4 lol works fine and is cheap to free lol
    i dont have an issue with the tire turning on my bike. Generally if the tire turns its a good indicator the straps are either too loose or to close to the bike. Im just throwing ideas out there for the OP on his request on ideas. a small steel framework with some verticals will prevent the tires from turning. hmmm ideas ideas
  15. Feb 27, 2011 at 10:49 PM
    ROCKSLINGER
    Robert
    Reno Nv
    Yup I use one as well notched it out and painted to match my bike. No blown fork seals here!
  16. Feb 27, 2011 at 10:50 PM
    red taco
    red taco Well-Known Member
    Cole
    La Verne, CA
    07 PreRunner Impulse Red Pearl
    If its just two bikes put the front tires pointing in touching each other. They will hold each other in place when the tie downs are tightened.
  17. Feb 28, 2011 at 12:04 AM
    red taco
    Cole
    La Verne, CA
    Actually here is an old post I did to help someone out with this same basic problem...
  18. Feb 28, 2011 at 12:13 AM
    ROCKSLINGER
    Robert
    Reno Nv
    I turn mine the opposite way to the corners and no bent bed
  19. Feb 28, 2011 at 9:19 AM
    red taco
    Cole
    La Verne, CA
    Ya that works too. Either way you still get the same outcome. Two bikes and no tires moving.
  20. Feb 28, 2011 at 9:51 AM
    xxaarraa
    xxaarraa Well-Known Member
    Not a rail mounted system, but very effective for me.
    $30 at harbor freight. Mounted on a 2x4 and bolted to bed.
