Motorcycle photo game
Discussion in 'Motorcycles' started by crazysccrmd, Aug 17, 2023.
  1. Sep 6, 2023 at 6:40 PM
    #121
    Redeemed
    Redeemed Well-Known Member
    Jeff
    Southern Maine
    05 SR5 with a "TRD Off-Road" sticker
    There are actually lots of them on that stretch of road. I was limited by the being able to park, get my bike in the picture and not be a general nuisance.
    fatfurious2[QUOTED] likes this.
  2. Sep 6, 2023 at 6:42 PM
    #122
    crazysccrmd
    crazysccrmd [OP] Well-Known Member
    Alaska
    Aprilia Tuareg 660
    They were about to send the butler down the drive to shoo your broke ass out of the way.
    w.adventures and grdgz97 like this.
  3. Sep 6, 2023 at 6:43 PM
    #123
    Redeemed
    Jeff
    Southern Maine
    :bikewheelie2:
    grdgz97 likes this.
  4. Sep 7, 2023 at 4:15 AM
    #124
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    I really could tell you "all of them". These bikes are incredibly reliable with just routine maintenance. There were some recalls and certain years are easier to live with but taking them in order:
    2003-2005 Gen 1. 2003 is first year in the US but available in Europe starting in 2001. Some of the early release bikes had valve guide issues. Clearances were off when the guides were pressed into the cylinder head and some bikes "ticked". They ran fine enough from what I understand but Yamaha did replace some cylinder heads. These early bikes also threw off a lot of engine heat onto the rider as they did not have insulation under the fuel tanks. Easy enough upgrade to just add some later.
    2006-2012 Gen 2. 2006 and 2007 had a weird throttle cam on the throttle bodies paired with a matching throttle tube that left many owners feeling the roll on throttle was "catchy" almost like an on/off switch. I had a 2007 and while it was noticeable I didn't find it objectionable. There were some electrical issues known as ground spiders for which a recall was issued. Yamaha used a weird approach to grounding everything and some harnesses corroded leading to weird electrical anomalies like dash lights staying on with the key off. There was a recall and a new wiring harness added to fix it. 2008-2012 the throttle cam situation was fixed, a small number of early bikes still had the ground spider issue creep up but not too many. There is also an updated cam chain tensioner that came out somewhere along the line. Most owners update the tensioner when they do a valve check mostly as a preventative measure. I updated mine on the 2007.
    2013-2015 Gen 3. 2013 is first year for electronic cruise control being standard but it was limited to 83 mph. This was fixed starting in 2014 and a 2013 can be fitted with a 2014 ECU if desired allowing cruise control up to 102 mph. You can also have Ivan's reflash your ECU to eliminate the limiter completely.
    2016-present Gen 3.5. Introduction of the 6 speed transmission. 2016-2018 they all had to be recalled for an issue with the second gear shift fork and gear dogs. This means a full engine out tear down and rebuild with new shift fork and some trans parts. I know owners who have had the recall done and owners who have passed on having it done. None of them have had any failures to date and this includes a few bikes with over 100k on them already. LED lighting is standard.
    If you want to know any more just PM me so I don't have to type a novel.......I'm on my second FJR and seriously doubt I'll ever NOT own one as long as I can still ride. For me it's been the best bike I've ever owned. Not perfect at any one thing just damned good at a little bit of everything. Oh, stock seats on all of them suck. Best bet is send your seat to a custom seat builder and let them work their magic. Laam Custom Seats is my pick.
    Cement_wheels[QUOTED] likes this.
  5. Sep 7, 2023 at 4:27 AM
    #125
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Thank you sir. Didn't mean to -> :threadjacked: but now I have a good FJR source!
    Expect a PM.
  6. Sep 7, 2023 at 4:41 AM
    #126
    BkerChuck
    Chuck
    Etters, PA
    Looking forward to it!
  7. Sep 7, 2023 at 6:41 AM
    #127
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Next up??
  8. Sep 7, 2023 at 9:34 AM
    #128
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Your bike next to flowers - single, couple, painted, or field
  9. Sep 7, 2023 at 9:36 AM
    #129
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Do these count? :D
  10. Sep 7, 2023 at 11:32 AM
    #130
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Remember guys, you have to take a picture of your bike for others to emulate, not just write what to do.
  11. Sep 7, 2023 at 12:09 PM
    #131
    fatfurious2
    David
    Ashburn, VA
    Then does that make me disqualified?
  12. Sep 7, 2023 at 12:25 PM
    #132
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    If you're dq'd, does that mean I'm dq'd too? :D
  13. Sep 7, 2023 at 12:51 PM
    #133
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    No, I’d say you’re good, just Johnny on the spot with the snag before the original photo was uploaded.
    The best way to keep the game flowing would be to have a photo of your bike and whatever ready to go for the next challenge when you claim it.
  14. Sep 7, 2023 at 1:34 PM
    #134
    Redeemed
    Jeff
    Southern Maine
    Guilty.
    I was just busy, and couldn’t post it immediately after my submission was OK’d.
  15. Sep 7, 2023 at 2:02 PM
    #135
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    I have spent quite a bit of time in the Fort Mill/Tega Cay area. Was just there this past weekend. Where the heck is this amphitheater??
  16. Sep 7, 2023 at 2:08 PM
    #136
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    They just put a lot of money into the Walter Y. Elisha park next to Fort Mill.
    https://maps.app.goo.gl/xHCVC28tnd3PhK5y8?g_st=ic
  17. Sep 7, 2023 at 2:12 PM
    #137
    7mMike
    7mMike Well-Known Member
    Nh/vt
    Tatts521 and gixxerphil like this.
  18. Sep 7, 2023 at 2:58 PM
    #138
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Interesting. I'm headed down there at the end of the month. Maybe I'll check it out. Thanks!
    w.adventures[QUOTED] likes this.
  19. Sep 7, 2023 at 7:19 PM
    #139
    w.adventures
    Nowheresville, SC
    So ugh, what’s the current challenge?
  20. Sep 7, 2023 at 7:24 PM
    #140
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    @fatfurious2 needs to post a picture for it still.
