Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Nov 24, 2020 at 5:51 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Anyone here in the mid Atlantic up for the MABDR? I’ve been looking at it and considering doing a section or two of it once it warms up in late spring.
    https://ridebdr.com/mabdr/
    spencermarkd likes this.
  2. Nov 24, 2020 at 6:10 AM
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
    I’m stupid. I thought you said you bought some for yourself.
    I already have some brotha. From Rogue Rider. But I appreciate it.
  3. Nov 24, 2020 at 6:52 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I don't have a harley anymore
    Tatts521 likes this.
  4. Nov 24, 2020 at 6:58 AM
    J_Anthony_
    Naomi, Lana
    I see that now. Haha.
    fatfurious2[QUOTED] likes this.
  5. Nov 24, 2020 at 12:07 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Biscuits likes this.
  6. Nov 24, 2020 at 6:39 PM
    fatfurious2
    David
    Ashburn, VA
    Multistrada footpegs were delivered today. Ill probably put them in tonight after work, or tomorrow
  7. Nov 24, 2020 at 8:30 PM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    I imagine it rides very smooth for a cruiser, but I'm not a big fan of the style.
    spencermarkd[QUOTED] likes this.
  8. Nov 24, 2020 at 8:57 PM
    fatfurious2
    David
    Ashburn, VA
    It will be a nice little mod
    w.adventures, uurx, Biscuits and 7 others like this.
  9. Nov 25, 2020 at 6:16 PM
    J_Anthony_
    Naomi, Lana
    Anyone have experience installing new handle bars on their Harley ?
    my new apes are here...
    Seems straight forward.
    Remove front controls ( throttle, brake, etc )
    Remove old bars from digital riser gauge.
    Disconnect old wiring and install new longer wires.
    Attempt to thread new wiring through the new bars.
    Tighten everything down.
    Any input would be great. I’ve heard it’s an easy install with the new ape bars / FXBB model... but then I’ve heard it’s the worst thing ever and it takes 8-10 hours.
    w.adventures, grdgz97 and uhplifted like this.
  10. Nov 25, 2020 at 6:25 PM
    fatfurious2
    David
    Ashburn, VA
    use fishing line/mechanics wire to help with fishing wires through bars. Take pics of connectors in case you need to de-pin. Although, my sportsters, I never went with internal wiring.
    Do you have ABS? I did it 2x times with my Sportsters with ABS, and they were never the same as stock. I tried using a syringe from the caliper going up, and the normal bleeding process.
    Its not that bad. I think with external wires, it took me 1-2 hours and that was taking my time/consuming adult beverages. Once you disassemble, you will see how things go back together. And hopefully not run into any issues. Are you keeping the original grips?
    uhplifted and J_Anthony_[QUOTED] like this.
  11. Nov 25, 2020 at 6:46 PM
    J_Anthony_
    Naomi, Lana
    Thanks man.
    I haven’t ordered new grips but I just might actually.
    Edit: No Abs
  12. Nov 25, 2020 at 6:56 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    It took you 2 days to do the exhaust so I’m guessing this is a 3 day task for you :anonymous:
  13. Nov 25, 2020 at 6:57 PM
    J_Anthony_
    Naomi, Lana
    My man...
  14. Nov 25, 2020 at 6:58 PM
    fatfurious2
    David
    Ashburn, VA
    if you dont do new grips, then you would have to be careful/use air to blow the glue out from inside the stock ones.. and that is annoying. I think new grips arent that expensive, and then you can either leave it on there, or cut it off - which is more fun
    J_Anthony_[QUOTED] and uhplifted like this.
  15. Nov 25, 2020 at 6:59 PM
    uhplifted
    Brian
    16 DCLB OR
    I think I paid 50 for my grips. I love em. Way better than stock. Plus I can get new rubbers for them in whatever color too when these wear out
  16. Nov 25, 2020 at 7:01 PM
    J_Anthony_
    Naomi, Lana
    Where did you snag yours from ?
    fatfurious2 likes this.
  17. Nov 25, 2020 at 7:04 PM
    J_Anthony_
    Naomi, Lana
    Good to know thank you dude. Def gonna snag some
  18. Nov 25, 2020 at 7:07 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    This is for a Sporty....but I would guess essentially the same process. As far as extended lines and running thru bars and all...
    https://youtu.be/Nr3edlWjrhQ
  19. Nov 25, 2020 at 7:09 PM
    J_Anthony_
    Naomi, Lana
    great vid.
    With my bars... I have no extended cables from the outside, works with the stock ones.. It’s all internal. So I’ve order a few wire extensions.
    Seeing that video ( spark noted it / jumped through it ). I think mine may be easier
  20. Nov 25, 2020 at 7:10 PM
    fatfurious2
    David
    Ashburn, VA
    grdgz97[QUOTED] likes this.
