Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Aug 13, 2021 at 6:03 AM
    Sacrifice
    Sacrifice [OP] Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Pick one you feel comfortable spending. Like said i have 2 from cycle gear that are always in clearance and ive used them for years. I only bought the noco to do lithiums which i found out isnt even necessary if the battery is good
  2. Aug 13, 2021 at 7:24 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Care to elaborate? I thought you needed specific lithium chargers for the higher float voltage and also so they didn't try to desulphate the battery and ruin it with too high of spikes?
    @BuzzardsGottaEat Any of the 1 or 2 amp will work great. You don't need a massive one for moto batteries. They have a 2amp 2port one if you're trying to get real fancy with it.
  3. Aug 13, 2021 at 8:06 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    FYI .. just got an email about an IMS Outdoors event being held in a few locations this year.
    Looks like there's lots of activities planned including demo rides on a bunch of Yamaha models. I might check out the one on 9/10 in Carlisle.
    https://motorcycleshows.com/schedule
    spencermarkd and uurx like this.
  4. Aug 13, 2021 at 8:59 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i meant unnecessary to leave a lithium on a charger. i ended up leaving my dirtbike off anything, battery still in and started just fine come april, parked from november.
    antigravity recommends not leaving a lithium on a charger and the cold doesnt bother them like it does standard acid
    uurx and spencermarkd[QUOTED] like this.
  5. Aug 13, 2021 at 10:01 AM
    spencermarkd
    Spencer
    Ohhh, yeah, gotcha. Self discharge on a lithium is like 1% a month. It's amazing.
    Also, my LiFePo4 HATES the cold if you need to actually start a bike below freezing. For storage though, it loves it. I think they actually recommend throwing them in the freezer if you're storing it haha.
  6. Aug 13, 2021 at 10:08 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    They do need "warmed" up in the cold (really just putting a current draw on it) before they operate normally
  7. Aug 13, 2021 at 10:22 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    I think this is a big pat of why I'm not moving to one of them. I ride almost year round and cold weather starting is required for my bike. I don't want to be the last one leaving work and find my bike won't start!
    w.adventures likes this.
  8. Aug 13, 2021 at 10:50 AM
    spencermarkd
    Spencer
    So what I've done in the past and will probably do again this year.. I took a like $9 Amazon set of heated grip pads w/ switch and harness, wired them directly to the battery, and put the switch near my key hole. Gaffer taped the grip warmers directly to the battery. When I turn it on the battery heats itself up internally and externally and worked surprisingly well haha.
    I didn't do it last year and had a few times where I'd have to bump the starter half a dozen or so times until the battery got "warm" enough. Only annoying part was that it'd momentarily drain the battery so low the first time or two that my clock would reset.
  9. Aug 13, 2021 at 11:17 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    ive heard turning on the headlight is enough usually.
  10. Aug 13, 2021 at 11:45 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  11. Aug 13, 2021 at 12:17 PM
    spencermarkd
    Spencer
    My headlights are LED and also don't turn on until the engine is started. All I get with key on is a DRL/parking light :annoyed: it wasn't enough draw to warm up the battery. If it's a halogen bulb and it turns on with the key, then yeah, definitely enough.
  12. Aug 13, 2021 at 2:00 PM
    uurx
    '12 t|x pro
    my ktm owners manual has a recommended cold start procedure for their bikes with lithium batteries in order to warm up the battery
    it kinda sounds crazy at first coming from traditional lead acid batteries all my life but new technology always seems like wizardry at first
    https://www.youtube.com/watch?v=aLS6iut15TA
    spencermarkd likes this.
  13. Aug 13, 2021 at 2:32 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I like the 2 port (and 4) for multiple bikes. Actually cheaper than buying two 1 port units.
    spencermarkd[QUOTED] likes this.
  14. Aug 13, 2021 at 2:53 PM
    spencermarkd
    Spencer
    Yeah they're wild. When I got my first one I thought it was an empty box at first.
  15. Aug 13, 2021 at 5:41 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  16. Aug 13, 2021 at 5:42 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Been riding the bike for 21 months now. 707 miles a month average!
  17. Aug 13, 2021 at 5:43 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Looks so naked without all your boxes and bags.
  18. Aug 13, 2021 at 5:47 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Doesn’t it though? Seems just blah without the panniers and top case. These bikes need their accessories
  19. Aug 14, 2021 at 7:16 AM
    uurx
    '12 t|x pro
  20. Aug 15, 2021 at 2:17 PM
    BkerChuck
    Chuck
    Etters, PA
    Went out to work on finishing off the currently mounted tires before I put on new shoes next weekend. Found a cool spot to take some bike pics.
    Tatts521, Doc Samson, uurx and 8 others like this.
