Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Apr 28, 2022 at 11:40 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Having bike envy right now; Coworker and I swapped bikes for the ride back from lunch.
    His Triumph Bonneville T100 sounds SO GOOD esp in the underpasses, but is def a cruiser bike. Felt like a sufficiently powered lazyboy compared to my 390 Duke.
    GHOST SHIP likes this.
  2. Apr 28, 2022 at 11:48 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    gabbo2112 and Gunshot-6A like this.
  3. Apr 28, 2022 at 11:51 AM
    Gunshot-6A
    Conner
    Everett, WA
    kidsmoke[QUOTED] likes this.
  4. Apr 28, 2022 at 11:55 AM
    kidsmoke
    Flyover Country
    exactly
    The other 'wheel in a hitch' approach leaves the drive train at risk. This is trying to do away with that.
  5. Apr 28, 2022 at 11:57 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Heard a thumper outside my house and thought someone stole my bike. My neighbor traded his older Suzuki Boulevard M109R straight up for a 2022 KLR 650 adventure. I gotta admit, it was much bigger looking than I expected. It seemed like a really great starting point, loved the already setup accessory ports and all that.
  6. Apr 28, 2022 at 12:01 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
  7. Apr 28, 2022 at 12:28 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Appears that drive train risk was simply traded for fork risk (as the triple-tree and forks were not designed to take a big pothole from that angle.)
    I'd use it for a short drive to get the bike to shop.
    Gunshot-6A likes this.
  8. Apr 28, 2022 at 12:36 PM
    kidsmoke
    Flyover Country
    Yup, that's risk, as I understand it. The risk of engaging the drive train.
    That's a good observation. Is that a legit concern though? The front end is designed to take the weight of the bike/rider/luggage - so 800#'s?? - and withstand constant varying force for thousands of hours.
    In this case it has less than the weight of the bike - 300? - riding on the nearly vertical front forks. And when it does hit a hole, it only has that 300 #'s resistance and can bounce freely.
    Thinking out loud here....
  9. Apr 28, 2022 at 12:42 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Never know when you’re going to need to clip off some Miata mirrors :rofl:
  10. Apr 28, 2022 at 12:44 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Have you ever ridden one? I have a buddy who is a die hard KLR guy. Owns an older one and the new one. I prefer the DR, personally. The KLR is a pig for a little guy like me ha.
  11. Apr 28, 2022 at 12:46 PM
    Gen3TacomaOBX
    S
    True BUT the forks are raked in the opposite direction under normal use. Potholes could theoretically exceed normal use forces. I have no hard data to back up my claim.
    The angled rake engages/compresses the front suspension. A trailing angle doesn't facilitate suspension compression therefore more of the impact will be transferred to the front wheel bouncing upwards and applying force on the fork brace, bearing and race. My $0.02
    Probably low pressure on smooth roads just don't hit a big pothole at speed.
  12. Apr 28, 2022 at 1:02 PM
    kidsmoke
    Flyover Country
    You're right on the angles. I'm thinking about the contrast in force. So if I'm two up doing 50 MPH on a 500 pound bike and see a pot hole and squeeze the brake - think about all the force moving into the impact - and the front end is engineered for that. Now think about 300#, no braking, and it can bounce freely away from the force. I don't have data either but it seems like its still a lot less.
    Another thing I thought of...what if you get a flat?
  13. Apr 28, 2022 at 1:18 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I have been sick since Monday and haven't felt comfortable riding due to it. Feeling some real FOMO right now seeing my bike parked in the garage every day.
    fatfurious2 and uurx like this.
  14. Apr 28, 2022 at 1:31 PM
    Kopasz
    Kopasz Well-Known Member
    Adam
    PDX
    ‘17 TRD/OR MT
    Just installed the Highway Dirt Bikes hand guards with integrated mirrors and a dash kit--very high quality product. My old Doubletake mirrors would need constant adjustment while riding.
  15. Apr 28, 2022 at 1:34 PM
    Gen3TacomaOBX
    S
    The tow method you have pictured can create forces similar to riding a wheelie then hard rear braking. over and over again.
    It'll probably work for many miles but I'm not a fan.
  16. Apr 28, 2022 at 1:38 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I was definitely taken back, when I saw them originally I assumed it would be the size of my drz400, maybe a touch bigger, but no that fuckers BIG.
  17. Apr 28, 2022 at 1:47 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    They aren’t small. My 2016 next to my old 750GS.
  18. Apr 28, 2022 at 2:10 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Weird, my doubletakes on the F800 have been great. The Acerbis are open guards, didn't want to drill the weights out in the Navi's bars and they were only like $32. That's shits and giggles price-worthy.
  19. Apr 28, 2022 at 4:20 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    fatfurious2 likes this.
  20. Apr 28, 2022 at 5:21 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    what happened to the Doubletake mirrors? Still have them?
