Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Aug 29, 2022 at 11:52 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I am searching for a decent light mount for a 1" bar. Have any recommendations?
    Like this:
    All-in-One Accessory Clamp - 1" Tube, Billet Aluminum - 2 Pack https://www.amazon.com/dp/B07Y5MB736
  2. Aug 29, 2022 at 12:13 PM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    Find a parking lot and really lean her over in second gear in either direction and then go hit some backroads. Its incredible what the stock suspension on a SS can do.
  3. Aug 29, 2022 at 12:43 PM
    fatfurious2
    David
    Ashburn, VA
    @Doc Samson put some knobbies on and come offroad again
  4. Aug 29, 2022 at 12:44 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Take note of the tires, David :rofl:
    uurx and fatfurious2[QUOTED] like this.
  5. Aug 29, 2022 at 12:52 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  6. Aug 29, 2022 at 1:10 PM
    fatfurious2
    David
    Ashburn, VA
    Didnt want to mess up the finish just yet on the bars.
    with those, im having a hard time finding a 1/2-20 bolt. Maybe i need to look harder
  7. Aug 29, 2022 at 1:23 PM
    Gunshot-6A
    Conner
    Everett, WA
    Lowes and Tractor supply both carry 1/2 - 20 hardware
    fatfurious2[QUOTED] likes this.
  8. Aug 29, 2022 at 1:36 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    well the process of putting my klx400 back together before the 15th started yesterday and so far ive hit two snags... the bolt on the clutch cover thing with the springs i snapped one bolt.... i did get it out and ill have to get a new one so hurray... but the other issue is i have no clutch engagement my lever is floppy and wont work at all so idk what the deal is so ill most likely have to take the basket back off to see whats up... other then that its all going well
  9. Aug 29, 2022 at 1:36 PM
    fatfurious2
    David
    Ashburn, VA
    Broken cable?
  10. Aug 29, 2022 at 1:37 PM
    Calamity_taco
    Jacob
    nope its a new cable and i can have the cable move the lever thing down below and i can see it activate down the tube where the rod thing goes but it wont do anything with the basket..
  11. Aug 29, 2022 at 2:24 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    So I'm a complete newb to motorcycles and I'm trying to figure out if I'm missing any parts for this install. I ordered a complete front/rear wheel set and I don't really know if I have everything needed to swap out the OEM stuff. I ordered tires, tubes, hubs, sprocket, brake disc, caliper relocation bracket, and a new chain. Did I miss anything?
    Since the hubs are made for my bike I'm assuming the axle/nuts will still work with the new wheels. Hopefully that's a safe assumptions.
    Thanks for the help guys!
  12. Aug 29, 2022 at 2:27 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    ABS Ring? What kind of bike?
    :worthless:
    Edit: just saw your post from yesterday. The WR? I'm assuming no abs on that, so ignore my entire post :anonymous:
    deadhed61[QUOTED] likes this.
  13. Aug 29, 2022 at 2:30 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    interesting....definitely didn't think about the ABS ring. Would it be smart to just have a one on each wheel set, or is it easy to swap out?
    2012 wr250r
  14. Aug 29, 2022 at 2:33 PM
    Calamity_taco
    Jacob
    i doubt your bike has abs which he did go back and update his post saying you most likely dont need that
  15. Aug 29, 2022 at 2:33 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Also, I welcome any and and all mod suggestions for this thing. :D next will be the rear fender delete to get rid out the large thing hanging off the back.
    GHOST SHIP likes this.
  16. Aug 29, 2022 at 2:34 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Yup, you and him are right. No ABS.
    Calamity_taco[QUOTED] likes this.
  17. Aug 29, 2022 at 2:35 PM
    Calamity_taco
    Jacob
    yup us riding dirtbikes dont need no stinkin abs lol
  18. Aug 29, 2022 at 2:51 PM
    Calamity_taco
    Jacob
    two possible options with my bike
    1.What has happened to you is that the clutch camshaft has rotated, and the operating rod isn't sitting in the notch in the bottom of the camshaft - just not working. You need to remove that operating rod, align the camshaft to where it normally goes (by the lever bolted on top), then push the operating rod through the clutchpack and the motor. It'll engage into the camshaft, and you'll feel and see it engage. Never at any point of this procedure do you need to pull in the clutch lever on the bars - just leave it alone the whole time.
    or these two rings that go in first i put in backwards which is possible
    2. 2 rings go in before the plates and fibers. There should be two different types. One is flat and the other is concave. Put the flat one in first and the concave one next with the high side in towards the flat one.
    ill have to go home tonight and check...
  19. Aug 29, 2022 at 3:13 PM
    GHOST SHIP
    GHOST
    That’s a fine thread 1/2”. Semi-common bolt. Seems kinda overkill for lights though. That what size BAMF supplies to replace your shackle hardware in their hanger kits.
  20. Aug 29, 2022 at 3:21 PM
    Calamity_taco
    Jacob
    that looks great man!
    gixxerphil[QUOTED] likes this.
