Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. May 29, 2023 at 8:37 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Can’t go wrong with a tail bag
  2. May 29, 2023 at 8:49 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    This is current
    Tatts521, Hafaday, Bushed and 3 others like this.
  3. May 29, 2023 at 8:58 AM
    but why tho
    but why tho Well-Known Member
    1991 Pickup
    Costco has these:
    https://www.amazon.com/COHO-Waterproof-latches-Removeable-storage/dp/B0BW8J2T6J?th=1
    For $50. I checked one out in person and they're really nice.
    fatfurious2[QUOTED] likes this.
  4. May 29, 2023 at 9:04 AM
    fatfurious2
    David
    Ashburn, VA
    I have a box from when I had my Scrambler. Just need to figure out a mount. Was thinking about these:
    Universal Aluminum Vehicle Hood Pins Quick Release Lock Latch
    https://www.amazon.com/dp/B0B564DYWT
    but why tho[QUOTED] likes this.
  5. May 29, 2023 at 9:05 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    but why tho likes this.
  6. May 29, 2023 at 9:09 AM
    fatfurious2
    David
    Ashburn, VA
    My rack is my DIY one. I can drill some holes to mount the pins. Wanted to put the push buttons inside the box, and pins on the rack side.
    It may have melted a little, but this is the box:
    Hafaday and oldtimertoyota like this.
  7. May 29, 2023 at 9:24 AM
    fatfurious2
    David
    Ashburn, VA
    This cost me $20 in materials. Better than the $100 options. Ive had several people ask me where to buy it too
  8. May 29, 2023 at 11:16 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
  9. May 29, 2023 at 11:22 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
  10. May 29, 2023 at 12:06 PM
    woodtickgreg
    woodtickgreg Well-Known Member
    Greg
    Michigan
    Today was install accessories day!
    Stainless steel motone engine guards.
    I like them as they don't stick out to far like some others doo.
    Nice and tidy.
    Then I installed a Madstad windshield. It's quick release and very adjustable with 2 knobs. You can adjust it for height and angle to reduce helmet wind buffeting.
    Right now it's set for about the same angle as the forks, it's just a starting point.
    View from the cockpit. I ordered the shortest shield they offered so I can look over the top, it has 4" of adjustability.
    The windshields are made to order and it really seems to be very high quality. I like that it only takes seconds to re.ove it for slower city riding and I can pop it back on for longer rides or on the highway.
  11. May 29, 2023 at 12:42 PM
    but why tho
    1991 Pickup
    I'm trying to figure out the jetting on the Navi. I'm watching @spencermarkd 's video on it right now, but basically so far:
    - Installed the DIY air intake and ended up losing ~4-5 mph off the top end (topped out at 45 mph instead of 50).
    - Pulled carb (thankfully only took about 10 min to remove) and installed bigger jets (38 pilot, 90 main vs 35 pilot, 85 main stock) and drilled out the Welch plug covering the pilot screw
    - Top end seems happier now and will hit 50-51 mph (so a little faster than stock?) so I think main jet is happy.
    - On stock idle/pilot screw settings the bike doesn't like to idle at all. Once warmed up it will die at stop lights and backfire/pop on decel. I can't tell if it's running too rich or too lean because both can cause backfire conditions and both can cause the bike to die (I'd guess it's too rich though with the bigger pilot jet).
    - Stock air/fuel mixture screw was set 1 turn out from factory, screwing it in any more to reduce fuel mixture would cause it to die so I backed it out another turn (2 turns out) and adjusted idle speed and it's not backfiring or dying yet but smells really rich.
    I haven't pulled the plug yet but I'm not sure what to do - either go back to 35 pilot, or just keep the 38? Since it seems to be running somewhat happily at idle at 2 turns out it seems like the 38 might be OK? I don't recall how the bike was running with the 35 and the new air intake (though it wasn't dying).
    If I had a welder I'd stick a bung into the exhaust and just use a wideband but that's not an option right now. :(
  12. May 29, 2023 at 1:53 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    With the freer flowing intake you will be pulling less vaccum potentially which will need bigger jets to maintain the same afr. No need to spend money on going wideband, the small honda aircooled motors (especially in stock bore / compression) are VERY forgiving. Pull the plug and see what it looks like, if you have a 95 main jet id throw that in to see if it gets better or worse at WOT.
    Usually with the fuel screw you set the idle speed lower than normal, get the bike heated up, then adjust the fuel screw in and out slowly till you find "the sweet spot" where it idles the highest, then open up (richen) just a bit more (like 1/8 to 1/4 turn) and do a final set of idle speed to desired idle rpms.
    Does the navi have a needle you can raise or lower?
    Also keep in mind that increasing/decreasing fueling via the fuel screw or slow jet will effect all other areas as well as fueling by all 3 circuits is cumulative.
  13. May 29, 2023 at 3:50 PM
    spencermarkd
    Spencer
    Sounds like it likes the 90 main, so that's good. If it were me trying to figure out the pilot I'd start by getting the a/f right for the jet thats in there now, so adjust the a/f screw until it idles highest, reset the idle screw to the appropriate RPM (Navi actually idles pretty high at factory settings, btw, you might be idling too low?), then verify with the a/f screw again that it won't go any higher. Repeat until it's happy and the highest it'll idle is at the appropriate idle, then go 1/8 turn further in.
    If you can get to that point with the 38, that's great, and fingers crossed this next test goes well. If it's still smelling pig rich, try giving the throttle some quick turns. If it's bogging when you open the throttle before increasing in rpm's, thats a good sign your jet is too rich and you should try the 35 again.
    And then to verify it likes the main jet it'd be easy enough to do a plug chop and check the color on that.
    Do you still have the stock exhaust on? Or did you get your smoke in already?
    nd4spdbh and but why tho[QUOTED] like this.
  14. May 29, 2023 at 5:16 PM
    spencermarkd
    Spencer
    100 miles, 5 towns, and 16 murals, channeling my inner Chuck today. It was fun cruising through the little towns with your head on a swivel looking at walls, I think of the 16 today 10 were surprise finds.
    This one is the soil of the various aquifers/wells in Moscow, ID, kind of goofy but had no idea it existed. There’s a really cool “water is life” themed mural around the corner but it got unsalvageably damaged a couple weeks ago by some bigoted ass.
  15. May 29, 2023 at 5:36 PM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    Very cool. I really like the robots.
    woodtickgreg likes this.
  16. May 29, 2023 at 5:41 PM
    but why tho
    1991 Pickup
    Thanks for the advice! I will try playing with the mixture screw tomorrow.
    The bike only popped once while riding today and while the idle seemed low it didn’t due on me once. The issue I have with the idle is if I raise it any more the wheel spins too far from the friction of the CVT. I don’t want to set the idle too high and have any issues with the transmission (if that’s a thing).
    I don’t have the exhaust yet so I guess I’ll have to do this again when that goes on.
    spencermarkd[QUOTED] likes this.
  17. May 29, 2023 at 5:41 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    RANT!!! Why do people put things up for sale then when you message them they don’t respond. Also if it’s sold TAKE DOWN THE AD!!!!
  18. May 29, 2023 at 6:02 PM
    Built2Ride
    JB
    Southeast
    This is awesome. I love seeing rally’s for a good cause.
    We have some murals in our downtown…one of the Wizard of Oz
    BkerChuck likes this.
  19. May 29, 2023 at 8:58 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Finally got out on the bike. Put a little under 40 miles on it today. Dipped my toe into interstate driving for a couple miles and hit 80 MPH on accident. :oops:
  20. May 30, 2023 at 4:15 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Way more things in life to be worried about. You probably hate people low balling you as well don’t ya?
