Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Jul 25, 2023 at 9:08 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    It’s all just time in the seat. Keep pushing yourself to get on it everyday. Even if you go no where just runs some drills in your yard. Stick a bunch of logs in your yard, your neighbors will love you!
  2. Jul 25, 2023 at 9:10 AM
    Built2Ride
    JB
    Southeast
    I am still getting used to the motor on the 890r. I have been used to riding either dirtbikes or big twins. This is way better Offroad, I can throw it around. The motor just requires more shifting than I am used to on the twins.
  3. Jul 25, 2023 at 9:15 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I think the HOA will love me more if I change anything outside of my house.. :mad:
    BkerChuck likes this.
  4. Jul 25, 2023 at 9:58 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    The heat is rough, I've been trying to get out early in the morning but even then it's been humid a lot of days.
    11k miles not too shabby! I was looking at my rear tire and surprised how much its worn already @3100 miles. The ContiAttack SM Evo is soft and grippy but doesn't seem like it will have a very long life span.
    Yup it's that red one in there, pretty cool bike with the V4 and single sided swing arm.
  5. Jul 25, 2023 at 10:18 AM
    FreshOldTaco
    kevin
    2003 Tacoma
    Sweet looking good. Tell him to keep an eye on the counter shaft seal, mine was leaking from new. Not badly just a very slow weep. Apparently it's a common issue on the 690/701. I finally made an appointment to have it fixed in a couple weeks.
    fatfurious2[QUOTED] likes this.
  6. Jul 25, 2023 at 10:35 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    Last pair of these tires I got 12.8k and it's the front one that wears out first! I bet the rear had another 1-2k left in it. I had that on my other FJR as well and it seems to work that way for most owners. Part of why I bought a Nomar tire changer.....
    Thinking as much as I don't really want to ride in downtown Philly that might have to be an upcoming mural run......
  7. Jul 25, 2023 at 10:43 AM
    but why tho
    but why tho Well-Known Member
    1991 Pickup
    I guess I get to learn how to do fork seals now.
    FlyingWolfe, woodtickgreg and uurx like this.
  8. Jul 25, 2023 at 10:53 AM
    BkerChuck
    Chuck
    Etters, PA
    I haven't done any inverted forks but conventional like my FJR are fairly straightforward. If you don't want the trouble of buying a special seal driver a piece of PVC pipe works well. So far I've found OEM fork seals to be better than the aftermarket stuff. YMMV
  9. Jul 25, 2023 at 10:53 AM
    but why tho
    1991 Pickup
    My friend has the seal drivers! I think he just has all the sizes so I should be set.
    BkerChuck[QUOTED] likes this.
  10. Jul 25, 2023 at 11:00 AM
    but why tho
    1991 Pickup
    Also @BkerChuck I just read a post on the Versys forum where someone tried several aftermarket seals and had their forks constantly leak till they went back to OEM... so thanks for the heads up! Will call the dealership and get some.
  11. Jul 25, 2023 at 11:02 AM
    BkerChuck
    Chuck
    Etters, PA
    Unsure how this applies to inverted forks but on conventional forks it's not a bad idea to replace any bushings while you have them apart. On my bike the bottom bushing see the most wear as it travels the furthest with suspension travel. The top bushing isn't too bad but you end up pulling it out when you tear them down so no point in trying to reuse it. Of course new fork oil goes without saying. I recently did my forks and upgraded fork springs while I was in there.
    Mad German and Built2Ride like this.
  12. Jul 25, 2023 at 11:20 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    You have a 3d printer, right? If they don't have the right diameter just print your own! I did that for my F800GS and it worked phenomenally.
    but why tho[QUOTED] likes this.
  13. Jul 25, 2023 at 11:20 AM
    FreshOldTaco
    kevin
    2003 Tacoma
    I'll ride with you, let me know if you want to make a plan
  14. Jul 25, 2023 at 11:24 AM
    but why tho
    1991 Pickup
    That's an awesome idea! If I can't get the drivers from my friend I'll do that.
  15. Jul 25, 2023 at 11:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  16. Jul 25, 2023 at 11:41 AM
    BkerChuck
    Chuck
    Etters, PA
    I'll keep that in mind! Most likely be in September at this point but have to see what I have coming up. I know Philly is the mural capitol with almost 4k murals but damn city riding can suck!
  17. Jul 25, 2023 at 12:36 PM
    spencermarkd
    Spencer
    This is what I did: https://www.thingiverse.com/thing:4702180
    Really simple, two cylinders and a hole, with just a .2mm gap between the two halves to allow it to split into two pieces.
  18. Jul 25, 2023 at 1:24 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Should have made them interlock :p
    spencermarkd[QUOTED] likes this.
  19. Jul 25, 2023 at 1:34 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    The VolksGromen :rofl:
    nd4spdbh and gixxerphil[QUOTED] like this.
  20. Jul 25, 2023 at 1:39 PM
    FreshOldTaco
    kevin
    2003 Tacoma
    Sounds good and September should be cooler at least. Totally agree, I avoid the city and mostly ride out in farm country on my favorite twisty back roads.
