Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Oct 2, 2023 at 4:49 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    All your talk about the FJR got me reading. I didn’t realized that the brake lever will actually engage both front and rear brakes. Neat!
    50Buck likes this.
  2. Oct 2, 2023 at 4:52 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Yamaha did that on the Super Tenere as well. Not sure if they've done it on any others, but it seems like a neat system.
  3. Oct 2, 2023 at 5:02 AM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    hey all quick question. yall remember when i was in colorado and i huged my friend the boulder? well i had no issues with it and overall havent since then.... (minus one incident where my dog did some wrestler move and hit it with her knee and it went into loads of pain)
    sounds like a good time but uh id see if your lens on your camera has gunk on it or something a lot of these are blurry af
  4. Oct 2, 2023 at 5:02 AM
    Built2Ride
    JB
    Southeast
    It’s very neat! It would throw me way off with the technical braking I do, but then again when do you see an FJR in the woods. Ha
  5. Oct 2, 2023 at 5:04 AM
    Built2Ride
    JB
    Southeast
    What was your question?
    Redeemed likes this.
  6. Oct 2, 2023 at 5:06 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    Actually the front lever engages all 4 pistons on the left front caliper and the top 2 pistons on the right front caliper. The rear pedal engages the rear caliper and the bottom 2 pistons on the right front caliper. It's a linked ABS system and works pretty well. Pretty unobtrusive and you don't really feel it much at all in normal braking. When you hit the brakes really hard for an emergency stop......You stop.
    Built2Ride[QUOTED] likes this.
  7. Oct 2, 2023 at 6:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah I'm not sure on the specifics of the FJR.
    I do know that on super tenere the "Unified Breaking System" I thought was going to get in my way but I actually really like it for the day to day.
    Super tenere sounds like it operates a bit different than the FJR. On the super tenere Rear brake will not engage the front ever. Front lever engages the front like normal and will add in rear brake via the ABS pump/accumulator based on things like speed and deceleration rate, pressure applied.
    It's seamless and you don't feel any pulsing etc (unless you stab the front lever, it will apply enough rear to hit actual abs threshold). The system does a good job of keeping the bike settled and pulled into the ground during braking rather than pitching forward tons (it still nose dives but with 7.5in of suspension it's gonna happen regardless)
    Now if you start braking rear first before front, there will be no linking of the brakes. So you can come into a corner and trail brake a bit with the rear then feed in the front as necessary. Or start with the rear get on the front and let off the rear and no linking will occur.
    The system will also allow the rider to overpower the rear if they wish, meaning if you are braking with the front lever alone and the system is feeding the rear it's calculated pressure, you can apply pressure via rear brake lever and as soon as pressure generated is greater the system will use that greater input. (Id have to look up if once you pass that greater pressure threshold if it unlinks all together meaning if you let off rear pedal there would be no rear brake or would it go back down to the calculated pressure of the abs pump)
    The system works great, keep fresh brake fluid and cycle the abs pump from time to time with a simple jumper (and make sure drain holes where the pump sits are unclogged) and people never have an issue.
    My only complaint...... There are a total of 5 sections of soft rubber lines (there are hard lines that run from steering stem to mid bike) for the front brakes and 2 for the rear. Makes for a slightly greater than I'd typically like spongy front lever feel.
    Built2Ride[QUOTED] and 50Buck like this.
  8. Oct 2, 2023 at 6:08 AM
    woodtickgreg
    woodtickgreg Well-Known Member
    Greg
    Michigan
    Yeah it probably was dirty, or I moved, etc. I noticed it after the fact when I got home. It's just phone pics.
  9. Oct 2, 2023 at 6:22 AM
    Built2Ride
    JB
    Southeast
    Very cool.
  10. Oct 2, 2023 at 7:36 AM
    Calamity_taco
    Jacob
    yup yup sadly my old phone does it alot so i gotta always double check it after i take one... stupid old iphone!
    woodtickgreg[QUOTED] likes this.
  11. Oct 2, 2023 at 7:37 AM
    Calamity_taco
    Jacob
    wait wtf i removed that question it shouldnt have been in any thing lmao wtf!
  12. Oct 2, 2023 at 7:41 AM
    Built2Ride
    JB
    Southeast
    Yeah when you quick in the gate like me, I see all…hear all…brapppp
    spencermarkd likes this.
  13. Oct 2, 2023 at 7:54 AM
    Calamity_taco
    Jacob
    lmao i guess so but ya just complications with my elbow after my crash is all... it locked up on me after hitting it when i went to lay down and it wouldnt let my hand let go of my controller... was rather painful!
  14. Oct 2, 2023 at 7:56 AM
    50Buck
    Ouch! I hope you've got insurance covering it.
  15. Oct 2, 2023 at 7:59 AM
    Calamity_taco
    Jacob
    uhhh no lol nobody knows i crashed on that trail
    w.adventures likes this.
  16. Oct 2, 2023 at 8:01 AM
    50Buck
    May want to change that. If you need PT, or worse, to get this resolved then it'd at least be nice to not have it be a bigger financial burden that absolutely necessary.
  17. Oct 2, 2023 at 8:02 AM
    Calamity_taco
    Jacob
    my insurance is awful sadly... found that out when i crashed last year. pt wont help i know that maybe an xray? to get it looked at but idk its been a month since i crashed and overall its fine unless something hits it i guess
    w.adventures and 50Buck[QUOTED] like this.
  18. Oct 2, 2023 at 10:07 AM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    One of our greatest benefits here in CA lol
    This is true. It helps having friends who live out of state who will send you the things the state won't let you buy. I had to do it with my Knox gloves as well, apparently CA deemed kangaroo leather illegal to purchase
    The beak does seem redundant along with the fender
    my BMW has the linked/integrated braking, it's nice. Took me a while to break out of my MSF training that dictates you start with rear, then apply front more as you lessen rear. On the BMW however, the front will always be linked to the rear unless in "Slick" (Track) mode, even if you start with the rear first. Very weird feeling when you're braking hard with both, and you feel the front take over both lol. The rear brake kinda loses pressure under your foot, then regains it as you lessen front brake lever engagement. Very weird feeling at first but doesn't affect anything as long as you aren't startled by it.
    RE: your comment about 5 sections of soft rubber lines, can you swap those to braided SS?
    The adult in me wants to slap you upside the head and then drive you to a medical office
    but I get it because I'm the same, and never get checked out unless its something that's really serious lol. Never got checked when I crashed at that supermoto class in April and hurt my shoulder and wrist, didn't get checked when I crashed my chest into my dirtbike handlebars a couple months back, and just this past weekend I'm pretty positive I hyperextended my right quad simply because I was getting too enthusiastic and competitive in spikeball at a friend's engagement party lol. Basically, if it ain't fully broke I don't fix it.
    That said, I wouldn't suggest living how I do, but I get it lol. Would definitely keep an eye on it, sounds like it might be a nerve issue if you're losing control of any motor function
  19. Oct 2, 2023 at 10:26 AM
    nd4spdbh
    SoCal
    There are definitely kits (to do it right its like 9 different lines - 5 for front brakes - 2 for rear - 2 for clutch) I have considered doing it for 1 - SS line goodness and a firmed up lever, but also extended top lines for bar risers. I was able to make some bracket extensions to move the hardlines so the clutch and brake soft lines that go to the bars have enough slack to use with my current bar risers but its almost too tight at full lock, but within reason. Problem is the full kits are 400+$ and im like.... im really only gaining a firmer lever feel.... 400$ is a lotta gas (well not so much these days) and riding haha.
  20. Oct 2, 2023 at 10:28 AM
    TacoTyusday
    Zac
    San Diego
    Lol yeah at that price I'd probably just deal with it as well.
