Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. May 3, 2024 at 11:38 AM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    Nah, no problem. Typically just hyperflash aka double the flash rate. If not that, it usually just won't work, so test it out.
    Personally, I prefer hyperflash on a motorcycle. Feel like it's more noticeable than the normal flashing speed.
    oldtoyman and gixxerphil[QUOTED] like this.
  2. May 3, 2024 at 1:11 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Ordered a set of tire irons, and later this summer I'll maybe attempt to change to a new set of tires myself. A little garage practice, fresh rubber. Then I'll know what to expect on the trail.
  3. May 3, 2024 at 1:58 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    Poor bike surrounded by parts! It's for once nice out as well so imma have to move some stuff around!
    w.adventures, 50Buck and TacoTyusday like this.
  4. May 3, 2024 at 2:17 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Set the tire out in the sun, it will more resemble the tire temp when you have to change on the trail and the warmer tire will install easier. If you have room and it's a otherwise difficult tire to change anyway, a small bottle of liquid soap is your friend.
    A trick we've used when breaking the bead loose on my Triumph's 150/70-17 rear tire tire which is difficult is to lay the wheel flat on the ground and use the sidestand from another bike to push down right near the bead. We had a 1250 GSA handy and it worked like a charm after a frustrating attempt with tire irons.
    Deathbysnusnu[QUOTED] likes this.
  5. May 3, 2024 at 2:23 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    So, I'm a complete dumbass. I didn't realize the TST signals wouldn't work on the Rally(apparently just the crf300L) I just ordered factory LED's from bikerzbits.
  6. May 3, 2024 at 2:36 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Out of curiosity, why wouldn't they work?
  7. May 3, 2024 at 2:53 PM
    TacoTyusday
    Zac
    San Diego
    Funny how regions dictate different behavior...lol. if it was nice out I'd take that opportunity to ride and do other stuff. It's when the weather's shit that I tidy up the garage or work on the bike.
    i'm sure for you it's probably too cold/miserable to do that stuff when the weather's crap though.
    maybe different plugs?
    Calamity_taco[QUOTED] likes this.
  8. May 3, 2024 at 2:58 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Apparently the Rally has a different wiring b/c of the 2 LED headlights(so I read). It even says it on their site. I just didn't pay attention :rofl:
    I'm sure it would work with some splicing, I just want a plug-n-play.
  9. May 3, 2024 at 3:01 PM
    TacoTyusday
    Zac
    San Diego
    dont ya just hate when your own oversight screws you lol
  10. May 3, 2024 at 3:07 PM
    spencermarkd
    Spencer
    Yeah, probably different plug or pinout. Bummer. I get it though, when I had my Navi and I went to LED's it was a PITA but I was bound and determined to not cut up my stock wiring harness at all. Bought a pack of OEM-style connectors (They used the old school bigger molex connectors on it) and wired up my own jumpers and crap to make it all work. Grom uses a newer style mini connector that I had to buy adapters for, I was sad.
  11. May 3, 2024 at 3:13 PM
    Calamity_taco
    Jacob
    Cold weather I do very much nothing lol. Rain I will work and clean things up or work in the garage. Nice days I'll go ride as well but ATM I'm just being lazy haha
    TacoTyusday[QUOTED] likes this.
  12. May 3, 2024 at 3:18 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Proper gravel break in too. Today has been a good day
  13. May 3, 2024 at 3:47 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Yeah, no one to blame but myself
    I'm not a fan of cutting the factory harness either. Luckily, the Europe/Asia markets got factory LED signals........so I'll have those :D
  14. May 3, 2024 at 4:15 PM
    Calamity_taco
    Jacob
    Tried going for a ride and my radiator cap started pissing coolant how lovely! Gonna need a new one..
    TacoTyusday likes this.
  15. May 3, 2024 at 4:15 PM
    Calamity_taco
    Jacob
    Sir that's asphalt
  16. May 3, 2024 at 4:58 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    I cut the connector off the stock signal and install it on the aftermarket. I am never putting stock signals back on.:der:
    spencermarkd likes this.
  17. May 3, 2024 at 5:59 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Absolutely worthwhile to know how to change a tire yourself if off road etc. Like stated below, set the new tire out in the sun to heat up some, and take the bike for a short ride with a 5-10 psi less than normal to heat it up as well.
    Im going to recommend against soap / water n soap as a tire lube. It never goes away, and water rusts things, especially when trapped inside a rim where it cant evaporate.
    If you plan on changing tires in any amount on your own grab some Ru-Glyde (or other tire mounting specific lube). Its cheap ~20 bucks for a gallon specifically meant for changing tires, actually helps with the bead stick once dry, no corrosion from water etc. I JUST had to refill my 32oz spray bottle after ~ 5 yrs and with tons of tire swaps. Napa sells it i believe or you can get it on Amazon
    https://www.amazon.com/Ru-Glyde-Mounting-Rubber-Lubricant-Bottle/dp/B000CIJUGK
    https://www.amazon.com/Ru-Glyde-Bottle-Lubricant-Protection-Motorcycles/dp/B0C34D46YY
    I also like to use cornstarch on my tubed tires tubes and a little on the inside of the tire itself to prevent chafing of the tube.
  18. May 3, 2024 at 6:00 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    I never would have thought of the water/soap as being a no no. Good info!
    Deathbysnusnu likes this.
  19. May 3, 2024 at 6:03 PM
    nd4spdbh
    SoCal
    Also this stuff is WAY slippier on rubber than soap (unless you use like pure soap... then get ready for spun beads), I have found lots of uses for it outside of tires when dealing with stretching rubber over things......................
    Deathbysnusnu and 50Buck[QUOTED] like this.
  20. May 3, 2024 at 6:04 PM
    50Buck
