Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Aug 12, 2024 at 12:51 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Benn running a couple lbs. less than stock for the street. Have yet to be able to get off road, but just checked and they are at 17f, 15r. :frusty:Guess I shoulda checked them before this mornings ride. She rode fine though. Haha
  2. Aug 12, 2024 at 12:54 PM
    Xinirgi
    Xinirgi Well-Known Member
    Canada
    2002 4Runner BL 2017 4Runner TRD 2023 KLX300 SM
    Probably nice and smooth! I'd like to run around there for future FSR roads, but don't have a compressor yet. For now I just have the compression backed out a few clicks front / rear. Really need to make an effort to dial in street / offroad settings at some point.
    Hafaday[QUOTED] likes this.
  3. Aug 12, 2024 at 1:08 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    That all makes sense. Mine have just the one nut tight to the rim. I do let some air out for the dirt roads, but not much. Baby Versys barely has enough giddy-up to spin 80/20's in the mud, no worries about spinning a tire on the rim :rofl:
  4. Aug 12, 2024 at 1:11 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    1 nut loose off the rim, the other tightened against the valve stem cap. The only tube I ever tore was at the valve stem with the nut on the inside. Regularly run 10-12 psi in the rocks.
    I eventually want to get another wheel for the rear to run a rock dedicated setup and a pines setup. Rock setup would get 2 rim locks and a bib mousse.
    Built2Ride and Hafaday like this.
  5. Aug 12, 2024 at 1:14 PM
    Sacrifice
    Sacrifice [OP] Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Don't hear anyone say anything about slave cylinders in the offroad stuff. The 690 is the only one I know that has an issue.
    I abuse the shit out of my clutch.
    Guessing by the picture its about the nuts. Ive always done 1 inside and 1 outside tight. The other thing ive seen is the outside loose and up against the cap so the valve can tilt if needed.
    Id agree. I never had a tube slip running at 12. It's typically the single digits that have the issue.
  6. Aug 12, 2024 at 1:14 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I have run mousse. Only reason to use 2 rim locks is if you're running "too soft" of one aka too small
  7. Aug 12, 2024 at 1:18 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    A dude on one of the exc/fe tech talk groups mentioned being able to get a ton of miles, even road use on them with 2 locks and basically cutting up a valve stem and turning it into a grease zerk. Haven't tried it in practice yet but I'd like to.
  8. Aug 12, 2024 at 1:21 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Always run one nut on either side of the rim. My dirtbikes have rimlocks.
  9. Aug 12, 2024 at 1:21 PM
    but why tho
    but why tho Well-Known Member
    1991 Pickup
    Dang, given how good the S10's hydro clutch is I'm surprised you don't like hydros more. I love hydraulic clutches, I put a Magura Hymec on the Versys that I loved. The Super Tenere's clutch is so smooth and linear. I love it.
    50Buck likes this.
  10. Aug 12, 2024 at 1:24 PM
    nd4spdbh
    SoCal
    Meh, the super ten's clutch is pretty hard and similarly smooth as any of my other bikes with cable clutches.
    25 yrs of riding motos, not one clutch cable has had to be replaced, just some lube here and there down the cable (like once every couple years). 2 yrs of super ten ownership, Bled the clutch once, rebuilt the master once (which again required bleeding).
    Pros n cons for sure, but I like simple.
  11. Aug 12, 2024 at 1:26 PM
    but why tho
    1991 Pickup
    It is a weighty clutch but I like that with the kind of bike it is. I don’t mind cable clutches but still prefer a hydro.
    I really wish the S10 had throttle by wire though.
  12. Aug 12, 2024 at 1:29 PM
    nd4spdbh
    SoCal
    S10 is throttle by wire, it doesn't look like it though due to having 2 cables that run down to the sensor at the throttle body to keep those electronics out of harms way and the elements.
    50Buck likes this.
  13. Aug 12, 2024 at 1:43 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    The firmness of the hydraulic took me a minute, but that's probably because the CB500X is geared toward newbies and has the lightest slipper clutch ever. One finger is all it takes. :cool: (Giggity)
  14. Aug 12, 2024 at 1:48 PM
    but why tho
    1991 Pickup
    Sure, but it still has cables that introduce slack/freeplay which is frustrating. And if they break you’re still SOL.
    nd4spdbh[QUOTED] likes this.
  15. Aug 12, 2024 at 1:57 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Just had a nice morning of riding. Set out on the first real ride on the 750 now that the ECU has been flashed. Took a few miles to get used to the seating position and how to hold my hands, arms and back. Got more comfortable as I put miles on. Rode for about 100 miles, noticed that vibes start at 5k on up. @ 60mph rpm’s are at about 4.5k so just about perfect and smooth. Bike had lots of power in the upper RPM range but it also has good pull in the 4-7k range which is good. I don’t think I will touch the gearing. The bikes handling is the best part. I can take corners (what is fast to me) and not even have to lean off the bike. It’s like it’s a point and shot and it’s on rails. Even better than the R3 IMO. It can take corners much faster and I can’t wait to get it to the track.
    Then I came home and jumped on the FZ1. Holy crap at first it was so weird because the steering is 100% different. The FZ1 I thought was buzzy but after being on the 750 it felt smooth as silk! lol. The FZ1 shows its weight but both bikes have plenty of power. I cruised through a construction zone and once I got passed the flagger I tried a clutch up second gear wheelie and ended up laying a 30’ black patch. I think the tires must have been a little cold. The FZ1 is obviously more comfortable for longer rides. As of right now the FZ1s brakes are way better than the 750. The 750 needs pads and the braided brake lines. They will be here soon so it will be interesting to see what the improvements are.
    So I want to keep both bikes. They each are real good at what they do. Some say the GSXR 750 is the best middle weight bike made and others say the Yamaha FZ1 is the most underrated sport touring bike made. The Kawasaki KLX 300 is a top rated small bore dual sport and the Honda Monkey is one of the best mini bikes out there. So what I am trying to say is I have just about the best of everything in motorcycles. I want to keep them all and I think I will. Now I just have to pay myself back a couple grand for buying the 750.
  16. Aug 12, 2024 at 1:57 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Any mousse that is going to be used on the road is stiff enough to not need two locks. Otherwise it'd get too hot on the road and get cooked anyways.
    I do like them. They soak up a lot of small stuff by absorbing the bump vs tube where the pressure wants to return.
    They are bitch to put in if they are too big.
    cynicalrider[QUOTED] likes this.
  17. Aug 12, 2024 at 2:00 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    N+1 haha
  18. Aug 12, 2024 at 2:06 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    just like that he gets pulled right back in! next the guys in here will convince you you need an ADV for what the KLX, FZ1, and gixxer can't do :rofl:
    glad you're enjoying it
  19. Aug 12, 2024 at 2:09 PM
    but why tho
    1991 Pickup
    S10 gang! Our leader @nd4spdbh will do all the convincing.
  20. Aug 12, 2024 at 2:11 PM
    oldtoyman
    Kevin
    North of Seattle
    Well the FZ1 is still for sale right now. Asking 8k so if someone showed up with that much I would most likely let it go. Not going to be dropping the price trying to sell. At least that way the wife still thinks I am trying. It is really that nice of a motorcycle in excellent condition.
