Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Mar 24, 2016 at 6:44 PM
    #801
    Sacrifice
    Sacrifice [OP] Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Why source a new motor? Jb weld should take care of that
  2. Mar 24, 2016 at 7:24 PM
    #802
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    How well does JB weld hold up? Also were in KS you located? I'm about an hour from K city.
  3. Mar 24, 2016 at 8:34 PM
    #803
    Round II
    Round II Member #12005
    So as far as street bikes I've owned gotta say this I'm digging the new ride more than any previous so easy to ride. Still only 75 miles on the clock so haven't had the chance to really run it out, can't wait for that first oil change! :bikewheelie2: Gonna be a good summer....
    Screen%20Shot%202016-03-24%20at%2011.16._321aa41e050356d6d8004a4b5bb62d1a27691a26.jpg
    pittim likes this.
  4. Mar 24, 2016 at 8:41 PM
    #804
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I haven't done it personally, but from what I've seen and heard it does just fine.
    Pretty much in kc
  5. Mar 24, 2016 at 8:54 PM
    #805
    Round II
    Its pretty strong stuff. I used it for the trim ring around the twin sticks and the crawler stick exerts some serious pressure and its held great so far.. Plus you can sand and paint it if you're anal about that kind of crap..
  6. Mar 24, 2016 at 9:11 PM
    #806
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  7. Mar 24, 2016 at 10:33 PM
    #807
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I know guys that JB welded quarters over holes they put in their clutch covers with their rear brake pedals when they would crash on the trails. Many of them rode with the quarter JB welded for a long time. As long as it sets and doesn't leak I;d say ride it until something happens. You're looking for a new engine anyway; might as well wait for this one to die.
    Most chains that fail it's not a lube problem it's just chain wear or material defects. Other thing is master link failure.
  8. Mar 25, 2016 at 4:07 AM
    #808
    MarX
    Mark
    NE Kansas
    Yeah I have JB Weld u purchased for whenever for my old bike I sold last. Surprisingly, never needed.
    Here's a pic of my current and old one that I finally let go last year. My Z got a new paint job though.
  9. Mar 25, 2016 at 4:46 AM
    #809
    cynicalrider
    cynicalrider #NFG
    Jersey
    True, I'm gonna give the JB weld a shot this weekend and see how I fair. Then I'll order new chain and sprockets. Rear sprocket is already pretty high but wouldn't mind going up another tooth or two.
  10. Mar 25, 2016 at 4:48 AM
    #810
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Gotcha. Probably the original owner never changed the chain and failed to mention it when you bought the bike. People. :rolleyes:
    As for JB Weld, if you prep the surface in good shape it's essentially a permanent repair. My parents have a '57 Ford tractor that we JB Welded the housing for the water pump on when I was in grade school and it's still holding up perfectly fine, completely leak-free. For something non-load bearing like that spot on your housing it should be fine for as long as you own the bike, as long as you apply it right.
    :notsure:
  11. Mar 25, 2016 at 4:48 AM
    #811
    MarX
    Mark
    NE Kansas
    Cool, keep us posted.
  12. Mar 25, 2016 at 5:06 AM
    #812
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Agreed. Just prep the surface well and build it up enough that you can smooth it back out inside/out of the case
  13. Mar 25, 2016 at 5:22 AM
    #813
    cynicalrider
    cynicalrider #NFG
    Jersey
    You guys think I can JB weld it without disassembling the engine? Or will I still need to open it all up to do it? If I gotta open it all up I might as well replace the case, no?
  14. Mar 25, 2016 at 5:30 AM
    #814
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I would pull it since that bearing if right behind there. If you can find a new case to replace it at the same time then yes I would, but doing jb weld is a cheap easy fix.
  15. Mar 25, 2016 at 5:45 AM
    #815
    Noelie84
    Noel
    Wales, Maine
    Definitely gotta open it up. JB Weld doesn't get along well with bearings, really.
    IF you can find a cheap case, it's worth replacing it while you've got it split. On the other hand, a tube of JB Weld is what, $5? You're already buying a new chain, obv. You're a better judge of what your budget is than we are.
    $.02
  16. Mar 25, 2016 at 5:52 AM
    #816
    cynicalrider
    cynicalrider #NFG
    Jersey
    True, I guess it will be a new learning experience for me too. The last motor I opened up was my 50cc dirtbike, and the only motor before that was a small engine for a small engine class in high school over 13 years ago lol. But I'm all about learning new shit and working on stuff so fuck it. I just wish my trucks frame swap will be done soon so I can get all the armor out of the garage and have space to work.
  17. Mar 25, 2016 at 6:39 AM
    #817
    Sacrifice
    KS
    DCSB OR 4X4 LT
    jb weld is probably your best bet anyways. youd have to find an entire case (both halves) in order to swap them both since they are machined.
    tearing down the motor isnt too bad, just a pain in the ass. ive never split cases before though and since im opting not to replace my rod bearing ill still have no experience.
    damn shitty luck though, seems like a few of us are having a rough start to the season already
  18. Mar 25, 2016 at 6:51 AM
    #818
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Please let us do all the motorcycle things this season... :pray:
    :bikewheelie::bikewheelie2::bikewhoops:
    Sacrifice[OP] likes this.
  19. Mar 25, 2016 at 7:54 AM
    #819
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I am one way or another. If I have to ride my grom at the supermoto meet then so be it!
    PcBuilder14 likes this.
  20. Mar 25, 2016 at 12:08 PM
    #820
    fleckosaurus
    fleckosaurus Certified Toyota Enthusiast
    Brian
    Versailles, KY
    2024 Tundra
    I got it! It's so nice!
