Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Apr 27, 2016 at 10:24 AM
    #1601
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    But you bought a dirt bike....o_O:frusty:
    If your so worried about Street riding then why not have a street bike....
    You supermoto guys make no sense sometimes....
    I get that you like the light smaller dirt bike feel on the rode....bit why should you go through the effort to upgrade it more to the street? Are you racing it on the street? Going the speed limit and regular driving doesn't take much....
  2. Apr 27, 2016 at 10:36 AM
    #1602
    gray223
    SE Missouri
    2014 Tundra Limited
    I feel like suspension for off roading is more needed then on road. Unless your racing on the street or driving inappropriately
  3. Apr 27, 2016 at 10:48 AM
    #1603
    Sacrifice
    Sacrifice [OP] Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    It's the exact same thing. It needs to be setup and sprung/dampened properly to get the best ride which can mean smooth and/or stable.
    You obviously haven't experienced a "set up" street suspension vs one that is factory. Cause they are very different. I'm sure @DoubleRGirl @TheMuffinMan and some others would agree.
  4. Apr 27, 2016 at 10:50 AM
    #1604
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    you say that cause i'm short????? and most bikes are sprung for someone 80lbs heavier than me????
  5. Apr 27, 2016 at 10:51 AM
    #1605
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'd say you need to ride a supermoto before you assume things about them. They are nothing like a dirt bike or a street bike. They can do both in their own way that is impossible to explain unless you've ridden one.
  6. Apr 27, 2016 at 10:51 AM
    #1606
    gray223
    SE Missouri
    2014 Tundra Limited
    I have zero problems or complaints on riding a factory suspension on the street:notsure:
    It does everything I need it to do... But maybe I'm really missing out on something
  7. Apr 27, 2016 at 10:53 AM
    #1607
    gray223
    SE Missouri
    2014 Tundra Limited
    Everyone has a different definition of both though. Like I've told sacrifice... Mine and his definition of off-oading vaires greatly.
  8. Apr 27, 2016 at 10:53 AM
    #1608
    DoubleRGirl
    Rebecca
    Rhode Island
    you're probably a normal sized human being. on my ktm i'd get bounced onto the tank every time i went over bumps, thought i was going to break my vagina. through some turns if there were dips or bumps i've lost my outside leg before from the rebound, pretty scary haha
  9. Apr 27, 2016 at 10:57 AM
    #1609
    gray223
    SE Missouri
    2014 Tundra Limited
    Im like 5' 11" 140lbs. Not sure if that's normal lol
    Yeah I could see how if your really light or heavy how things may need to change. That's makes since.
  10. Apr 27, 2016 at 11:01 AM
    #1610
    DoubleRGirl
    Rebecca
    Rhode Island
    i'm 5' 105lbs so you're much more normal build than me
  11. Apr 27, 2016 at 11:06 AM
    #1611
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Pics or you're 4'10 and 220 :D
  12. Apr 27, 2016 at 11:08 AM
    #1612
    DoubleRGirl
    Rebecca
    Rhode Island
    this could also be true. dang i'd be a bouncy ball
  13. Apr 27, 2016 at 11:08 AM
    #1613
    gray223
    SE Missouri
    2014 Tundra Limited
    I know that if you are doing it in Street tires then it's not really off roading to me. My 650 has 60/40 tires and can do some light trail riding but it's slicker then crap in most cases. Yeah we can ride down gravel and dirt roads at speed to but that's not off roading to me either lol.
    I can see how yes you can do some off roading on some Street tires. But It wouldnt be much of riding. If it's dry though I could see you could get away with a little more stuff.
    Either way you can't say the supermoto is some do all bike.
  14. Apr 27, 2016 at 11:15 AM
    #1614
    Noelie84
    Noel
    Wales, Maine
    It'd be easier to jump over you than to walk around you...
  15. Apr 27, 2016 at 11:16 AM
    #1615
    DoubleRGirl
    Rebecca
    Rhode Island
    haha that's one of my fears, being short AND fat. can't be both
  16. Apr 27, 2016 at 11:26 AM
    #1616
    Noelie84
    Noel
    Wales, Maine
    Don't tell that to Winnie the Pooh.
    Edit- Or this guy:
  17. Apr 27, 2016 at 11:29 AM
    #1617
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Everything is a compromise in a bike that is taken on and off-road. You can optimize the suspension for the street but off-road it will handle like crap and either reduce how much fun the dirt is and/or cause a crash when pushed too hard. Same goes for off-road though what I've found is that it's much harder to hit the limits of an off-road setup suspension riding around on public roads; if you're taking the bike to the track that's a whole different ball game. I always have slanted my bikes more off-road on the suspension and usually my tires are my limiting factor and not the suspension. If I put something soft and grippy like TKC-80's or Karoo 3's on my old 950 or 690 I was scraping pegs in the twisties easily even with a 21" front wheel. However TKC's are super soft (hence the grip) so pinch flats and bent rims are a problem riding moderately aggressive (for me) off-road on the bigger bikes unless I keep the air pressure up but then grip on dirt suffers.
    Choose your bias and just get out and ride. Play with settings and you'll find one that clicks with you.
  18. Apr 27, 2016 at 11:32 AM
    #1618
    DoubleRGirl
    Rebecca
    Rhode Island
    how do i look?
  19. Apr 27, 2016 at 11:41 AM
    #1619
    Noelie84
    Noel
    Wales, Maine
    Yeh're dead sexy!
    DoubleRGirl likes this.
  20. Apr 27, 2016 at 12:22 PM
    #1620
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Who gives a shit if his definition of offroad is different than yours? Just because he doesn't run the Dakar everyday like you do apparently doesn't mean anything.
    I bet Sacrifice has just as much fun offroad as you do, and waaaaaaaaaaaaaaaaaaaaaay more fun on road than you do. I don't have a bike yet, but I'm pretty sure the whole point of being on a motorcycle is to just fucking enjoy it. And in that sense, a supermoto that CAN do it all is way more enjoyable than some woods bike.
