Motorcycles BS Thread 2.0
Discussion in 'Motorcycles' started by Sacrifice, Mar 8, 2016.
  1. Jul 11, 2020 at 12:46 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Surging idle sounds like an air leak to me. Your boots on correctly and tightly? You can use propane or even carb cleaner to check for it, really any flammable gas/aerosol. Spray it around the boots and if the engine surges there’s your leak.
    fuel leak where? bowl? drain screw? overflow? Check bowl gasket and that you have the float needle the correct orientation. I put one in backwards accidentally and it caused it to not stop gas from coming into the bowl and over flowed.
    Start by trying to nail where it’s leaking, you got this
    Tacos4ever15 likes this.
  2. Jul 11, 2020 at 12:48 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Uh oh. Bad ideas are here
  3. Jul 11, 2020 at 1:01 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    id like to try out a hypermotard
  4. Jul 11, 2020 at 1:12 PM
    fatfurious2
    David
    Ashburn, VA
    First impressions while im still on the test ride.. much different riding position, tank is low. Cornering is good. Its a barebones bike. More so than my 48.
    The Icon is $9500
    The Icon dark edition is 8900.
    this one is a Full Throttle
  5. Jul 11, 2020 at 1:46 PM
    amRRussel
    amRRussel A guy with a truck
    Andrew
    2011 Access 4banger 4x4
    Driver Mod
    Well... I think I am putting the 600RR up for sale. Went to a Triumph dealer and am now obsessed with the Scrambler 1200.
  6. Jul 11, 2020 at 1:46 PM
    fatfurious2
    David
    Ashburn, VA
    The riding position is so much different. I am going to think for a while on this switch..
    w.adventures likes this.
  7. Jul 11, 2020 at 1:47 PM
    fatfurious2
    David
    Ashburn, VA
    Im making people switch already?!
  8. Jul 11, 2020 at 1:55 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Different bad? Or different how??
    That yellow bike is sweet!
  9. Jul 11, 2020 at 2:02 PM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Is the girlfriend aware of this shenanigans??
  10. Jul 11, 2020 at 2:05 PM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Thats way too upright for me, i do like the scramblers tho
    fatfurious2[QUOTED] likes this.
  11. Jul 11, 2020 at 2:45 PM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    You advice is very much appreciated, thanks for that.
    I just finished up with the bike, and the news is good overall. While I wasn't able to run it with the rebuilt carbs due to the fuel leak, I was able to remove and replace the original carbs (did it four times today total) and the bike began running like it used to. I assume that when I swapped back to the original carbs, I must have had an air/fuel imbalance which caused it to run so poorly. I did drain them before removing them the first time, so I suppose that was part of it.
    Anyway, the end result is that the bike seems to be running like it did before, so I'm really happy that I can continue to ride it while I diagnose the rebuilt carbs and see where I made a mistake. To answer your question, I actually couldn't find the source of the leak. I was watching closely with a flashlight while cranking the starter, but it just seemed to flow out of different areas. The leak is not in a low place, such as the fuel bowl gasket; it seems to be higher up... which worries me. I'm wondering if there is a crack in the housing.
    Either way, the good news is that I still have a bike I can ride while I put the other carbs back on the workbench to disassemble and inspect.
    I learned a lot today.
    Tacos4ever15 and w.adventures like this.
  12. Jul 11, 2020 at 3:03 PM
    fatfurious2
    David
    Ashburn, VA
    Not bad. Its much like the FZ09. Very upright and wide bars. The yellow one that i test rode, the seat was very forward. And the tank is low. Feels like something is missing right in front.
    Im sure the Icon has a flatter seat so I could slide back a little bit. At 5'11" it felt a little small. It still has good pickup.
    I think the Harley is quicker, even though its heavier. The Ducati is 400lbs. And if i put an exhaust, that drops. I looked at some of the accessories and they are so much less than Harley! Thats good haha.
    I think it would be a fun bike. I just need to decide if its for me. Right now, im leaning 60/40 yes. But also need to pay down my bike some more. And if they dont have one when im ready, ill have to order one. I havent ordered a bike since the FZ09.
  13. Jul 11, 2020 at 4:44 PM
    amRRussel
    Andrew
    Driver Mod
    I've been eyeballing, researching, watching a bunch of videos for a while. Today was the first time I actually saw one in person and sat on it.
  14. Jul 11, 2020 at 4:55 PM
    spencermarkd
    Spencer
    Finished designing and printing a new battery box cover so I took my CT90 out and laid down some super thick burnouts with it
    :anonymous::anonymous::anonymous:
    But really y’all need to ditch the groms and get super old beat to shit CT90s :thumbsup:
    TSAVO, uurx, EdgemanVA and 3 others like this.
  15. Jul 11, 2020 at 5:37 PM
    fatfurious2
    David
    Ashburn, VA
    She doesn't approve. I told her i was going to think about it for a month or 2. Then ill have the Harley for a year, and ill be in better shape
  16. Jul 11, 2020 at 6:25 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    check the float needle seats. Sounds like they are not sealing. You can bench test the floats and the seals before you install next time. Search on ninjette.org for tips. I’m over there as well.
  17. Jul 11, 2020 at 6:36 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    How much you want for it? Need to buy @FreshOldTaco sv650 first and now yours...
    FreshOldTaco likes this.
  18. Jul 11, 2020 at 6:41 PM
    w.adventures
    Nowheresville, SC
    spencermarkd[QUOTED] likes this.
  19. Jul 11, 2020 at 6:43 PM
    w.adventures
    Nowheresville, SC
    If you are only at 60/40 sounds like you didn’t love it.
  20. Jul 11, 2020 at 6:51 PM
    w.adventures
    Nowheresville, SC
    @spencermarkd whats the top speed of a ct90? I finally got to take the Grom out for a little ride yesterday without the kiddo. Speed tables are a blast going full speed over them!
