Motorex Trail Gear Oil 75w?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bulldog, Nov 10, 2022.
  1. Nov 10, 2022 at 7:50 PM
    bulldog
    bulldog [OP] Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
  2. Nov 10, 2022 at 7:52 PM
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra 2016 4Runner
    Just use 75w90 and not worry about it. Toyota and Lexus both told me that’s what they use. Even have emails from corporate to prove it.
  3. Nov 10, 2022 at 8:17 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Post em up
  4. Nov 11, 2022 at 4:53 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Here where we have freezing cold winters that gear oil doesn't work well. A buddy that owns a large auto repair shop working on many 4wd brand manufactures vehicles only recommends using the 75w toyota oil, or an equiv. like what shell has, or bmw. Say the other stuff like 75w-90 can get like sludge in cold weather not being able to shift in 4wd, or back till the truck warms up enough.
    usmc2msu likes this.
  5. Nov 11, 2022 at 5:19 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That was true for 2nd gen Tacoma. 3rd gen Tacoma has a thread full of people getting 4x4 shifting problems with 75W90.
    And 3rd gen Tundra switched to ATF for the transfer case, like GM trucks, in case you were curious.
    zoo truck likes this.
  6. Nov 11, 2022 at 7:38 AM
    zoo truck
    None
    If i recall, i think one of my earlier toyota 4x4 pickups used atf in the transfer case.
  7. Nov 11, 2022 at 9:12 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^I put Red Line MT-LV in my transfer case last week. The oil is red. I now suspect Dexron III would work, but might cause leaks due to seal compatibility issues.
  8. Nov 11, 2022 at 11:54 AM
    bulldog
    SW MO
    2023 Pro
    The Motorex looks tempting.
  9. Nov 11, 2022 at 11:58 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I wouldn't run that. That oil is designed to work with a clutch that endures a ton of slipping to modulate power. It says it has an extra additive to enhance clutch engagement. You don't want that in your Tcase.
  10. Nov 11, 2022 at 12:04 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    But why...?
    Price isn't that good...
    Don't really know if it's suitable...
    Why not just buy one of the ones where the manufacturer recommends it for use in place of the OEM 75w? Redline MT-LV, Ravenol MTF-3, Etc.
    Big tall dave likes this.
  11. Nov 11, 2022 at 12:09 PM
    fourfourone
    Agree. Just buy something that is proven to work well.
  12. Nov 11, 2022 at 12:10 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I run this in my MTX tC2 that uses the vague 75W GL-4 Toyota spec low viscosity fluid (that is $70/qt from Japan). Shifts fantastic. Only 4k miles on my Taco so haven't had to look into all the fluids yet, but if it calls for the same stuff I wouldn't hesistate to run it in this as well.
  13. Nov 11, 2022 at 12:25 PM
    bulldog
    SW MO
    2023 Pro
    Anyone have links to deals on OEM 75W? I’m a shade tree mechanic and will be serving the truck for the first time myself.
  14. Nov 11, 2022 at 12:32 PM
    splitbolt
    NW Arkansas
    Additives aside(couldn't find a VOA for Motorex)...
    Just going off their TDS, the Motorex is a bit thinner(0.5 cSt) and has 1/2 the flash point of Toyota LF.
  15. Nov 11, 2022 at 12:59 PM
    bulldog
    SW MO
    2023 Pro
    What about Fuchs Titan Sintofluid FE 75w?
  16. Nov 11, 2022 at 1:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    This has been discussed extensively: https://www.tacomaworld.com/threads/‘16-newer-transfer-cases.636057/
    Red Line actually updated its MT-LV datasheet to declare compatibility with Toyota LF after being queried by a TW member. Couple of 3rd gens in my off road club already ran it through winters with good results.
    drizzoh[QUOTED] likes this.
  17. Nov 11, 2022 at 2:43 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Awesome thanks. I had contacted them as well regarding my Scion and noticed they updated it on their website as well since then.
  18. Nov 12, 2022 at 8:36 AM
    captrussia253
    PNW
  19. Nov 12, 2022 at 8:50 AM
    captrussia253
    PNW
    75w90 has a pour point -38*. I have a hard time believing it will sludge up. 75w is only used for better mpg according to Toyota.
  20. Nov 12, 2022 at 8:51 AM
    captrussia253
    PNW
    https://youtu.be/3le9ZT5HUlk
