Mount Ammo Can to Bed Rails - How-To
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ETXTacoma, Mar 5, 2016.
  1. Mar 5, 2016 at 2:24 PM
    ETXTacoma
    ETXTacoma [OP] Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    End Result First...
    Here is what you need to be able to complete this.
    Drill with a 1/2 Drill Bit
    Hammer and some sort of punch
    Sharpie
    .50 Cal Ammo Can
    You can get all of the following at your local Lowes store.
    2 - 1/2" x 1 1/2" Bolt - Item Number 396472 - $1.43 ea
    4 - 5/16 1 1/2" SS Fender Washer - Item Number 365174 - $0.45 ea
    2 - 1/2" x 3/8" Nylon Spacers - Item Number 137094 - $1.51
    5 pack - 1/2" Spring Nut - Item Number 598780 - $5.18 - Found in ELECTRICAL! Leaves you with three left over for other projects!
    Step 1. Drill 1/2" Holes in the Ammo Cans, Does not matter the spacing, I just put them closer to the ends, account for the fender washers. Mark the holes and use something to make a smell dent in the side of the ammo can so it will be easier to drill.
    Step 2. Put the spring nuts in the bed rail
    Step 3. Attach the Ammo Can with the bolt and washer in the follow order.
    Bed Rail - Spring Nut - Nylon Spacer - Fender Washer - Ammo Can Side - Fender Washer - Bolt through all of that.
    Done!
    You can leave the ammo can green, or you can paint it like I did with some Rustoleum spray paint.
    I plan on figuring out a way to be able to lock this up in an easy way, it is impossible to steal this unless someone carries a 19mm wrench around with them. All I plan on keeping in here are tie down straps for the bed and some stuff that I just want to keep dry.
    Total cost for all of this was less than $30.00 for the Lowes hardware and the Ammo Can at my local Army Navy Store.
  2. Mar 5, 2016 at 5:28 PM
    Zach O
    Zach O Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    Nice! I have been thinking about doing this. I want to do one on each side.
  3. May 16, 2016 at 8:22 AM
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    definitely doing this soon!
  4. May 16, 2016 at 8:27 AM
    ETXTacoma
    Steven
    Tyler, Texas
    It is a pretty easy mod to do. I keep all of my tie down straps and a extra set of gloves in it all the time and they stay dry very well. Now that I have the SnugTop on the bed, I am moving this box to the end of the bed to the tailgate area.
    FYI. I would be sure to get either correct T-slot nuts or get the 1/2" Spring Nuts from Lowes. Don't get the 1/4" as they wont hold things well as I found out when building a CB Antenna mount.
    Pirhett[QUOTED] likes this.
  5. May 16, 2016 at 8:36 AM
    Pirhett
    Rhett
    San Diego
    Stock...
    Thanks for the advise man! Ill prolly use it and make a lock for it and put recovery gear, flares, and other emergency stuff since most of it is behind my rear seat and the other day when I saw a motor cycle accident and stopped to help my falres weren't accessible so I had to use my maglight to move traffic around it
  6. May 16, 2016 at 8:41 AM
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    Love mine! I added carriage bolts to the bottom to keep the box front twisting down when its loaded up with stuff...
  7. May 16, 2016 at 8:42 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Good plan. Since I am 6'3" no one can really sit behind the drivers seat. So I ended up buying a BlueRidge Overland Gear seat back Molle panel from them and using that as like my easy to reach stuff. So I keep flares, some tools, and other needed things on that. Could look into something like that?
  8. May 16, 2016 at 8:43 AM
    ETXTacoma
    Steven
    Tyler, Texas
    That is actually a really good idea that I was trying to figure out a way to do that. Mine rattles a lot when going over bumps and such or when it has some heavy stuff in it. So that right there may be a great way to prevent that.
  9. May 16, 2016 at 8:43 AM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Very Cool! I'd do this in a heartbeat, but I'm running out of real estate on my bedrails
  10. May 16, 2016 at 8:45 AM
    ETXTacoma
    Steven
    Tyler, Texas
    I hear ya! I have a Hi-Lift taking up my passenger side and now that I have the SnugTop I don't have easy access to the front of the bed. Going to have to figure something out on that.
    One thing I did think about it, if you can find a taller ammo can, you could almost make it to where it sits on the bed side possibly if it is mounted at the front of the bed.
    Thebennyhana likes this.
  11. May 16, 2016 at 8:53 AM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Interesting thought... access to the front gets get pretty difficult when I'm ready to hit the trail with a bestop, hi-lift on R, axle/shovel mount on L and husky box with winch and gear at the front... this ammo box solution looks as handy as a shirt pocket though... may have to rearrange.
  12. May 16, 2016 at 8:53 AM
    Pirhett
    Rhett
    San Diego
    Stock...
    lol yeah Im 6'3" but when I need to I make that front seat fit a 5'10" lol
    Ive thought about the molle cover tho but now sure if I would loose comfort that my wetokoles give
  13. May 16, 2016 at 8:54 AM
    Pirhett
    Rhett
    San Diego
    Stock...
    can you show a pic of the inside? curious how the carriage bolts look in there
  14. May 16, 2016 at 9:00 AM
    ROCdermody
    Sure, it's at home now, but the round carriage bolt head sits up against the bed, the ammo box is sandwiched between a pair of fender washers and a pair of nuts. Use the inside nut to adjust for plumb, then lock it down with the nut between the bed and the box.
    Pirhett likes this.
  15. May 16, 2016 at 9:50 AM
    ETXTacoma
    Steven
    Tyler, Texas
    I never even noticed the bottom strap part of the panel. It is so low on the seat it doesn't mess with me.
  16. May 16, 2016 at 6:32 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    If you have them in the front corners just utilize both the bed side rails as well as the front rail and the boxes don't budge. I did that with mine and they're rock solid.
  17. Apr 4, 2018 at 10:18 AM
    truckstick101
    truckstick101 Master of the lean
    2018 Tacoma TRD Sport 4x2 Cement
    Hey how did you paint this? would like more info please!
  18. Apr 4, 2018 at 10:27 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Just simple rustoleum flat black paint is all I used.
  19. Apr 6, 2018 at 6:29 PM
    tmangini2
    tmangini2 Well-Known Member
    Charlotte NC
    2021 Tacoma TRD Off Road
    good idea thanks man, give it a try
  20. Apr 8, 2018 at 1:33 PM
    KissmyTaco
    KissmyTaco Well-Known Member
    Eric
    Phoenix, AZ
    2017 Tacoma MGM DCSB TRD Sport
    I have a Gashole
    Did you mount the bolt high enough so that the top of the can is below the bedrail?
    Definitely interested in this mod, but I also want to be able to use a cover.
