Mount spare upside down?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by D Soulman, Jul 2, 2021.
  1. Jul 2, 2021 at 5:08 AM
    D Soulman
    D Soulman [OP] Well-Known Member
    Dan
    Fargo, North Dakota
    Is there any reason you can’t mount the spare with the valve stem on the bottom? My current set up has leaked before and I would like to be able to check/air it without dismounting it. Sorry if this has been addressed..
  2. Jul 2, 2021 at 5:26 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    A rubber or perhaps plastic spacer to cushion the impact on the front face might be helpful for this, if carrying an alloy spare. If using a steelie and you don’t care about cosmetics then no problem.
    You can put a TPMS in but it doesn’t help much since the Tacoma does not monitor more than 4 TPMS’s. Which irks me.
    I wonder if anyone makes a 5 tire, aux TPMS monitor…
  3. Jul 2, 2021 at 5:27 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. I have had it that way since I got the Taco. If you put the stem to the sides or front, there is almost no chance of hitting it off road.
    Big tall dave and Skydvrr like this.
  4. Jul 2, 2021 at 5:28 AM
    daveeasa
    David
    PNW
    This one actually looks halfway decent, might be worth a shot to monitor your spare only?
  5. Jul 2, 2021 at 5:29 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Turned mine over the first week I had it.
    tonered likes this.
  6. Jul 2, 2021 at 5:31 AM
    daveeasa
    David
    PNW
    Personally, I’d prefer to carry a pump or compressor than stress too much about the pressure inside the spare before it’s installed.
    Though I do have 5 alloys for my summers (and 5 steelies for my winters, only 4 with TPMS)
    It would really be so much better if the Tacoma just monitored and displayed all 5. Sigh.
    shakerhood and YF_Ryan like this.
  7. Jul 2, 2021 at 5:35 AM
    daveeasa
    David
    PNW
    Out of curiosity, @tonered , are you able to reach the valve without crawling underneath like elastigirl? I assume not so is this something you do regularly just to feel good about the spare? Or do you just give it a kick or punch to check?
    tonered likes this.
  8. Jul 2, 2021 at 5:43 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    If you have an inflator chuck with the double end, you can inflate it in place.
  9. Jul 2, 2021 at 6:41 AM
    D Soulman
    Dan
    Fargo, North Dakota
    Are you referring to the impact of road debris, etc? If not, what impact?
  10. Jul 2, 2021 at 6:45 AM
    daveeasa
    David
    PNW
    The claw at the end of the chain scratching the front surface of the wheel during raising / lowering. And the (admittedly small) clamping forces along with shifting due to temp changing volume of the tire.
    Likely minimal but some guys spend thousands on wheels.
  11. Jul 2, 2021 at 6:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I love being able to do most anything under the Taco without the need for a jack. Just a pleasure compared to the ever lower cars that we have had in the past.
    I check all of our spares every 6mo. I do air checks every two or three weeks. That spotted two punctures on the other cars before needed to touch the spares.
  12. Jul 2, 2021 at 7:44 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    I flipped the tire shortly after getting my truck. Dropping it to do some work not long after I jammed the chain just as the tire started to come down. Then twisted the head off the chain lift rod.
    When flipping the tire to put valve stem down, the chain lifts it from the bottom of the tire and it will not stay level. Fairly certain the tire wobbling around is what caused the chain to bind up. Just watch out for that.
    https://www.tacomaworld.com/threads...ank-tool-what-now.720237/page-2#post-25641299
  13. Jul 2, 2021 at 7:53 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Having the compressor puts my mind at ease for sure!
    Bought the truck new, and my very first oil change the Toyota Dealership did their 40 point inspection or whatever it is and noticed my spare had no air in it. From the factory that tire was useless, lol. They aired it up and it's held air ever since. It's now 10 years old. I'll be getting a new spare this year to replace it, even though it's never been used.
  14. Jul 2, 2021 at 8:11 AM
    D Soulman
    Dan
    Fargo, North Dakota
    Copy that thanks.
