Mountain Bike Carrier Ideas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by emund, Oct 2, 2020.
  1. Oct 4, 2020 at 7:54 AM
    #61
    slowboater
    slowboater Well-Known Member
    With the 1 up it looks like you need to remove bikes to open the tailgate. No? That wouldn't work for me. On a trip I need to get to the dog crate easily and don't want to remove bikes every time I stop.
    Malvolio[QUOTED] and emund[OP] like this.
  2. Oct 4, 2020 at 8:09 AM
    #62
    emund
    emund [OP] Well-Known Member
    Arroyo Grande, CA
    2017 Inferno TRD OR 4x4
    This is a great thread I appreciate all the input from you all :thumbsup:
    Malvolio likes this.
  3. Oct 4, 2020 at 8:16 AM
    #63
    TacoPlatter
    TacoPlatter Well-Known Member
    Michigan
    2017 Double Cab Off Road
    Another vote for spending the $ on the 1Up rack. I love mine and use it continuously. Easy to put on and off and folds up for storage. Bikes stay secure.
  4. Oct 4, 2020 at 8:21 AM
    #64
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  5. Oct 4, 2020 at 12:09 PM
    #65
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Yes, you need to remove the bike closest to the tailgate in order to tilt the rack down and have the tailgate clear. I think most hitch racks are at least that involved unless you fork over big bucks for a swing out hitch from 1UP or another manufacturer.
  6. Oct 4, 2020 at 12:16 PM
    #66
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Tray style rack works for me. I like leaving the bed open for other stuff.
    This is a Raxter rack, about 10+ years old.
    Flatlandr, DamnHippie and emund[OP] like this.
  7. Oct 4, 2020 at 1:00 PM
    #67
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    PM me! I can get that sorted for you!
  8. Oct 4, 2020 at 4:29 PM
    #68
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    There’s interest...
    I have the Kuat, I like it but do have to add an extra Velcro strap around the front tire - I’ve bounced my fatbike out of it before...
  9. Oct 4, 2020 at 4:42 PM
    #69
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    I've used quite a few options depending on circumstances:
    Lay it down in the bed if just me and one bike. This is by far the safest option IMO - it's more out of sight laying down, can't run it into low-hanging structures, and should be safe if you're rear ended. Quick and easy, no wheel removal needed (6 ft bed).
    Rockymounts rack on front utility rail. I use this if I have too much gear to lay the bike down but not enough it takes up the whole bed. Only issue I've had is my DVO fork has a tapered thru axle so there is some play in the mount. The mount does lock for added security, but I still lock it with a chain too.
    Tailgate pad. Rides with 3-5 bikes where we don't need all the room in the bed. Quick and easy. I don't like them in very wet/dusty conditions. Fork legs and stanchions can sometimes rub on the pad causing wear, and they can tip over. I have an old model Dakine without the tie down loops. Risk is damage to bikes if rear-ended. Have had this happen once. It sucked but other driver's insurance replaced all damaged parts no questions asked (Mercury insurance)
    Thule T2 with 2-bike extension. Solid rack. I can put the tailgate down with a bike on the nearest tray. Use it when I have a full bed of gear. I don't really like using the 2 bike extension due to its length but it's an option if we have too much gear to use tailgate pad. Risk damage if rear ended.
    I have lots of friends with One-up racks. A couple times we've had one come close to backing all the way out of the hitch receiver on rough roads. To secure that rack you tighten a bolt which spreads a pair of wedges against the receiver tube rather than a thru-bolt like Thule. This either comes loose or works its way out on rough roads. For me that makes One-up a no-go unless they've fixed it.
    Personally I would never consider roof rack an option. It's not a matter of if but when I'd drive it into my garage or other low clearance structure. Hell no.
    Finally I've had a home made wooden rack before. Bikes stand upright. Worked ok but took up a lot of space in the bed. Could easily hold 5 bikes though for local shuttles. You can also stand bikes upright strapped down with tie down straps. Works pretty well too.
    OP, each option has pros/cons and circumstances where it will work well or not at all. Consider the situations you'll likely encounter and which options might work in each. You may decide to use several options like I do depending on circumstances. Sometimes you have to make compromises
    emund[OP] and mtip like this.
  10. Oct 4, 2020 at 5:17 PM
    #70
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    yeah, that’s why I include a Velcro strap with every SideRide Set!
    TroutBum[QUOTED] likes this.
  11. Oct 4, 2020 at 5:22 PM
    #71
    TacoStarv
    TacoStarv Well-Known Member
    New Jersey
    2020 Black Tacoma SR
    I use a bomber strap for when I’m going solo, and I’ve used a sea sucker when I need to carry two but that has only been once. My bed was being use to carry all the food for our trip so that was my only option at the moment.
    emund[OP] and TroutBum like this.
  12. Oct 4, 2020 at 5:40 PM
    #72
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    This is why I went with the Thule T2 Pro XT 2 over the Kuat. It's better at dealing with multiple bike types IMHO.
  13. Oct 4, 2020 at 5:47 PM
    #73
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    Two pieces of scrap carpet. One has soft side to the tailgate. One piece had the soft side to the bikes. Together it's enough padding to protect and lock the bike in. I did about 700 miles like that Thursday and Friday. It's free and easy to remove so you don't have dust build up and scratch the tailgate like permanent pads.
  14. Oct 5, 2020 at 9:10 PM
    #74
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    Yakima Hangover! I’ve got the 6 bike model, but they’ve also got a 4 bike version.
    Skada likes this.
  15. Oct 5, 2020 at 9:33 PM
    #75
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  16. Oct 6, 2020 at 12:09 AM
    #76
    emund
    Arroyo Grande, CA
    Wow that sucks about being rear ended with the tailgate pad! Great post of info. I’m with you on the roof rack, scary.
  17. Oct 7, 2020 at 11:26 AM
    #77
    emund
    Arroyo Grande, CA
    It looks like those Bomber straps are $129 is that what you paid?
  18. Oct 7, 2020 at 11:41 AM
    #78
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Wow! Thats a lot of money! You get the EVOC (my favorite) tailgate pad for $160.
    RockiesTaco and Malvolio like this.
  19. Oct 7, 2020 at 12:10 PM
    #79
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    It was a good post. Lots of practical info. One thing about the tailgate pad and getting rear ended. Pretty much any of these solutions will kill your bike if you are rear ended. And, of course, I am in NY where it is only a matter of time until some dumb ass hits me from behind because they were texting and driving.
    Did you settle on a decision yet?
  20. Oct 7, 2020 at 12:19 PM
    #80
    Alden
    Alden Well-Known Member
    Alden
    Atascadero, CA
    2018 Cement Tacoma DCSB TRD OR AT 4x4
    Dakine Tailgate pad for 3+ bikes
    Rocky Mounts Split Rail hitch rack for 1-2 bikes
    Bomber Strap for 1 bike or when I'm camping and don't want the hitch to get in the way.
    Skada, TacoStarv, mtip and 1 other person like this.
