Mountain Bike Help
Discussion in 'Sports, Hobbies & Interests' started by whippersnapper02, Jul 20, 2010.
  1. Jul 20, 2010 at 7:23 PM
    whippersnapper02
    whippersnapper02 [OP] Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    I have a chance to buy a 2004 Specialized S-Works Enduro for $1500. It was only used a few times by the previous owner. The previous owner is a co worker and I trust him. He wouldn't see me junk but I have no idea what the value is. I know there is a brake recall on these and it has no been done. Is it worth it?
    FRAME
    FSR technology, A1 TransForm Monocoque w/ M5-XX ORE technology DT, butted rear triangle, forged / relieved HT & BB, sealed cartridge bearings, 130mm travel, replaceable derailleur hanger
    REAR SHOCK
    Fox Enduro Brain, air spring and rebound adjust, remote Brain with Trail Tune. Threshold (sensitivity) adjust
    FORK
    Fox Float RLC TALAS, externally adjustable travel 80-125mm, air spring, compression & rebound adjustable damping, lockout, with threshold adjust, alloy steerer
    HEADSET
    1 1/8" threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight carbon top cap w/alloy bolt
    STEM
    Thomson, CNC 7000 Series Aluminum, 5 degree rise
    HANDLEBARS
    Specialized Carbon Fiber XC Low Rise bar, 6 degree upsweep, 8 degree backsweep, 640mm width
    TAPE / GRIPS
    Specialized MTB grip, black, double density Kraton
    FRONT BRAKE
    Shimano M-965 XTR hydraulic disc, metallic brake pads, 6" XT Rotor
    REAR BRAKE
    BRAKE LEVERS
    FRONT DERAILLEUR
    Shimano M-960 XTR, 34.9mm clamp, bottom pull
    REAR DERAILLEUR
    Shimano M-952 XTR, long cage, standard spring
    SHIFT LEVERS
    Shimano M-965 XTR, STI integrated shifter/lever combo
    CASSETTE
    Shimano M-960 XTR, 9-speed, 11x34t, titanium top 4 cogs
    CHAIN
    Shimano CN-7701
    CRANKSET
    Shimano M-960 XTR Hollowtech II arms
    CHAINRINGS
    44Ax32Ax22A, 7075 Aluminum, 44 Anodized, 32/22 nickel-plated, 4-bolt, 146/102/64mm pattern
    BOTTOM BRACKET
    Shimano M-960 XTR, Octalink spline, combined w/ crank, 68mm shell, 133.5mm spindle
    RIMS
    Mavic CrossMax SL Disc Tubeless compatible, 26�
    FRONT HUB
    Mavic CrossMax SL Disc with Mavic QR
    REAR HUB
    SPOKES
    Mavic CrossMax SL forged aluminum
    FRONT TIRE
    Specialized Enduro Pro 2.2�, aramid bead, 120 tpi
    REAR TIRE
    TUBES
    Specialized Ultralight, presta valve
    SADDLE
    Specialized Telluride with Body Geometry technology, leather cover, titanium rails
    SEAT POST
    Thomson, 7000 Series Aluminum, 2-bolt adjust, 30.9mm x 367/410mm
    SEAT BINDER
    Alloy collar with Q/R, 34.9mm clamp I.D., black
    NOTES
    Chain stay/seat stay protector, derailleur protector, seatpost water bottle mount, reflectors, owners manual
  2. Jul 20, 2010 at 7:37 PM
    mentose457
    mentose457 Well-Known Member
    I would check ebay for any similar bikes to see what they are going for.
  3. Jul 20, 2010 at 7:39 PM
    timmaayyy
    timmaayyy Well-Known Member
    Tim
    NW Arkansas
    06 Double Cab for your listening pleasure...
  4. Jul 20, 2010 at 7:51 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Thanks guys. I checked ebay and I didn't find much.
  5. Jul 21, 2010 at 1:53 AM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    FR:Camburg 2.5 Performance System,RR:Icon AAL w/Bilstein 5100. K&N drop in,DynoMAX,Optima yellow top.
    That's a nice rig,will it suit your riding needs? It is six years old. I say borrow it,ride it take to your local trails and even a bike shop, see if it needs anything and ask them for their opinion. I've bought bikes on "a good deal" and later re-sold because it was a wrong size,didn't feel right or changed too many parts
