Mountain Bike help...
Discussion in 'Sports, Hobbies & Interests' started by TWLTRD11, Jan 28, 2012.
  1. Jan 28, 2012 at 9:17 AM
    TWLTRD11
    TWLTRD11 [OP] Well-Known Member
    Baltimore, MD
    '11 Double Cab TRD Sport
    Looking at getting into mountain biking. I've looked at Treks and I am pretty sure thats what I want to pick up unless I find a Giant or Specialized with similar specs. I have found this one locally want to see if you guys can help me. If there is anything else I should look for, if this one sounds like a great way to start, etc? Suggestions welcome.
    Here are the specs for the bike:
    2010 Trek Mountain Bike-Gary Fisher Wahoo Edition available.--only ridden twice.
    The only mountains this bike has seen are mountains of laundry and medical bills.
    Unfortunately a health problem has prevented me from using it
    Accessories included--Tire Pump, Cup Holder Installed, Lock
    Buy a helmet and you're all set!
    $450 Negotiable
    Specs:
    Color: Matte Black
    Frame Alpha Gold Aluminum, butted & hydroformed tubing, cold-forged dropouts & bottom bracket, G2 Geometry
    Front suspension SR Suntour XCT V3, preload, custom G2 Geometry, 51mm offset, 100mm travel
    Size 17.5
    Wheels Formula DC20 alloy front hub, Shimano M475 alloy rear hub; Bontrager AT-550 disc 26 inch
    Tires Bontrager 29-2, 29x2.1"
    Shifters Shimano Altus, 8 speed
    Front derailleur Shimano Altus
    Rear derailleur Shimano Acera M360
    Crank Shimano TX M171, 42/34/24
    Cassette Shimano HG31 11-34, 8 speed
    Pedals Wellgo ATB, boron axle, alloy cage
    Saddle Bontrager Evoke 1
    Seatpost Bontrager SSR, 27.2mm, 20mm offset
    Handlebar Bontrager Low Riser, 25.4mm, 5mm rise, 9 degree sweep
    Stem Bontrager Approved, 25.4mm
    Headset 1-1/8" threadless, semi-integrated, semi-cartridge bearings
    Brakeset Tektro Novela mechanical disc brakes, 6-bolt, 160mm rotors
    Grips Bontrager Race Lite
    The pictures look like the bike is in great condition. Let me know what you all think.
  2. Jan 28, 2012 at 9:21 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    can we see these pics?
    but if this is going to be your first mtb then trek does make a nice one. just check for rust and such. make sure the wheels spin without any noticable drag from the hubs (indicating the bearing inside isnt good) but since its only been ridden twice i dont see how much could be wrong with it.
    Good Luck!
  3. Jan 28, 2012 at 9:29 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I've got the 2011 wahoo and there are only two differences in components i can see. the 2010 has mechanical brakes and shimano rear der. Other than that they are about the same. I really like mine.
    It sounds like a good deal but i would keep an eye out for other bikes also. A few guys on here have gotten lucky and found some good buys with better components for around that price or a little cheaper although they might be a little older.
  4. Jan 28, 2012 at 9:31 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    Sounds like a good entry level bike.
    If you can get it for $400, that much better.
    I say go for it. Aluminum frame with Mech discs, good to get out and have fun with.
    Give he wheels a spin, to see if they are true before buying. Also check if the rotors are flat, not warped.
    17.5" is a medium frame, check the ride height to see it it fits you well and give it a ride before pulling the trigger.
    Happy Trails
  5. Jan 28, 2012 at 10:31 AM
    OzarkMK
    OzarkMK Active Member
    Springfield Missouri
    Grey Access Cab. Currently Unmodified
    I agree it sounds like a good entry level bike. Or a bike you can ride for years if you don't get the itch to always have something better. The price seems about right. A bike bought new for 800-1000 usually sells for about half that after it's a couple of years old.
  6. Jan 28, 2012 at 11:07 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Sounds good. I picked up a new Trek with disc brakes a couple years ago when I first got into biking. Forget exact model. Its served me well so far and I have no complaints.
  7. Jan 28, 2012 at 11:10 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    since this is your first mountain bike i would say the trek and not a giant or specialized
  8. Jan 28, 2012 at 12:07 PM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    My brother has this one. It's geometry seems a little different than my 3900, like I'm stretching out to reach the handlebars. I would suggest a test ride before you buy it, that's really the only way to know if you'll like it or not, no matter what components it has.
  9. Jan 28, 2012 at 3:58 PM
    TWLTRD11
    Baltimore, MD
    Here are the pictures:
    I do know the 17.5 inch will fit. I have sat on the 2011 Wahoo in stores here in Atlanta. The price does say negotiable so I might try work on that. I just don't see the point in going out to buy a new one for a couple hundred dollars more when I will be getting used to trails, etc. I have found a 3700 disc series here close to me as well for $350. From what I have read, the 3 series bikes have 26 inch tires compared to 29s on the Wahoo. A guy in the shop here suggested the 29 over the 26.
  10. Jan 28, 2012 at 7:04 PM
    Quo Fan
    Quo Fan Well-Known Member
    Paul
    Southwest Virginia
    2017 Barcelona Red TRD Off-Road
    Nerf bars
    For the price, the bike is spec'd well. Ride the heck out of it, and find out what you really want in a bike. Then save your dollars and buy a bike that will do what you want.
  11. Jan 29, 2012 at 11:38 AM
    TWLTRD11
    Baltimore, MD
    Got on craigslist today to get the number for the Wahoo and both of the bikes I mentioned are gone! Guess I should have jumped a little quicker on first one. Anybody have one for sale around the South or suggestions of where to find some more besides checking craigsist?
