mountain bike maintenance
Discussion in 'Off-Topic Discussion' started by jeckel7234, Dec 13, 2011.
  1. Dec 13, 2011 at 11:57 AM
    jeckel7234
    jeckel7234 [OP] Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    I'm trying to get into mnt biking, before I go dropping good money into it I'm using my buddy a older trek nothing special something you would find at wal mart. But it hadn't been used in atleast two years other than the tire wear and pressure is their anything else I should do/inspect. And I'm 6'2'' 260lbs
  2. Dec 13, 2011 at 12:14 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    -Give us model and year of bike
    -make sure it's comfortable
    -make sure no fork seals or shocks are leaking
    -make sure brakes function correctly and have good brake pads
    -make sure it shifts smoothly in all gears
    -check for loose spokes and/or bent rims
    -smooth operation of all bearings
  3. Dec 13, 2011 at 12:37 PM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    on top of that check the chain for rust and/or broken or cracked links. you might invest in a good wax based chain lube. it helps keep mud and dirt off the chain. jut make sure you wash it off good and reapply every time you go through dusty or muddy places.
    check the frame for anything that is bent or cracked too. trust me, a cracked frame can lead to a really bad day really fast at a really really inopportune moment.
    when checking brake function check the cable for frays. im assuming it is a cable brake system instead of hydraulic if it is a walmart special. there should be little knobs where the cable goes into the brake handle that can be used for fine adjustments and there should be an allan wrench set screw where the cable attaches to the actual brake contraption that you can loosen up to pull some slack out of the cable if it has stretched.
    Now get out there and ride. Mountain biking is a blast
  4. Dec 13, 2011 at 12:40 PM
    takern
    Tanner
    Virginia
    oh i forgot to add. do not use WD40 on the chain. it may seem like a good idea at first but it will do evil evil things to you. if you do not use a wax based lube some old engine oil works pretty good. as with the wax lube, be sure to wash when dirty
  5. Dec 13, 2011 at 1:23 PM
    jeckel7234
    Drew
    VA
    05 Tacoma
    awesome thanks alot, im going to pick up the bike now
