mountain bike question
Discussion in 'Sports, Hobbies & Interests' started by SR54x4, Jun 12, 2011.
  1. Jun 12, 2011 at 7:47 AM
    SR54x4
    SR54x4 [OP] Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    i ride a cannondale prophet and recently when climbing hills the chain keeps jumping out of gear then back to the gear i have selected. its a real pita. it seems to be jumping from the back cassette, mostly on the larger rings. i also find it really happens when climbing hills and even more when im standing and climbing. the teeth on my cassette are definatley worn, but not down to nothing yet. do i need a new cassette, or is something out of adjustment?
  2. Jun 12, 2011 at 7:52 AM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    sounds like your drivetrain is worn out. Go to a shop and ask them to check your chain wear. If it is past 1.0 you are in trouble. That means you need to replace the chain, cassette, and most likely some or all of your front chainrings.
  3. Jun 12, 2011 at 7:54 AM
    SR54x4
    Mark
    Hudson Valley
    im really hoping its just the cassette, i figured i would ask hear to brace myself for damage when i bring it to the bike shop this week.
  4. Jun 12, 2011 at 7:56 AM
    6spdtaco
    VT
    Taco
    if they end up concluding that your drivetrain is effed, you can try to save some cash by just replacing the chain and cassette. Ride it with the original rings for a while and see if it slips off the front.
  5. Jun 12, 2011 at 8:42 AM
    SR54x4
    Mark
    Hudson Valley
    yea i think i might just try that. the chain is like new, and the front rings dont ever seem to slip. maybe ill just start with a new cassette (looks like a decent one runs about $50) and go from there.
  6. Jun 12, 2011 at 8:53 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Sounds like cassette/chain mismatch or wear or torque issue when standing climbing tweaking chain line. I had an old Diamondback FS bike that would do that when torqued up climbing....or cable stretch and the adjuster on the rr derailleur just needs a twist or 2
  7. Jun 12, 2011 at 8:57 AM
    tonyplanet
    tonyplanet Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    It's more than likely your cassette. With the tight spacing these days, 9spd and now mountian bikes are moving towards 10spd, things become more finicky.
    I just finished replacing my own cassette. Cassette and chains are the most wear items on your drivetrain. Your cassette will last longer if you maitain your drive chain and keep it clean i.e. replace chains when they need to be replaced, and lube.
  8. Jun 12, 2011 at 8:58 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    it sounds to me like its the rear derailer. it will do exactly what you are talking about if the adjustment cable is to loose. after a while that cable stretches. It can be tightened by turning the adjustment where the cable goes into the derailer (usually in a clockwise direction)
  9. Jun 12, 2011 at 9:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I agree. I would check the Rear Derailer adjustment first....and possibly the shifters. Then maybe the condition of the chain.
  10. Jun 12, 2011 at 9:12 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Are you using correct rear sprocket to correct front? I.e. 1 in front and 1-4 in back, 2 in front and 3-6 in back, etch. Keeping chain straight as possible!
  11. Jun 12, 2011 at 9:13 AM
    fatty ac1d
    fatty ac1d Well-Known Member
    Kansas
    15 MGM DCSB SR5
  12. Jun 12, 2011 at 9:48 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    It sounds like it's ramping. With teeth worn, they definitely will slip down. upon torque, especially when doing climbs. If it weren't doing it under load, then I would say it's a der adjustment. Most likely a combination of both due to the stresses.
    But if the teeth are worn that really should be replaced, regardless.
    I would say a new cassette would benefit you the most at this point.
