Mountain Driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Jan 16, 2012.
  1. Jan 16, 2012 at 9:32 AM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    Hey I got a question, being that I am from Michigan and the land is flat and I never had to change gears other the 4 if I was towing something.
    How should I shift when going through the mountains. I dont want to ride my brake all the time. I know I can down shift to help control my speed. But I dont really know how. Meaning at what speeds is it ok to shift into lower gears without screwing up my transmission.
    Thanks
  2. Jan 16, 2012 at 9:36 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Say you are going down a hill... Drop the gear low enough to where you are at a speed you are comfortable at. These transmissions are made to hold a truck back on a decline for example. There is no magical number... It is all about your comfort level. When going up a hill, put the gear low enough to where the truck isn't always shifting gears (that number for me is usually 3). Your truck is better suited for the mountains than you think it is. Play around with it for a little while and you will have the hang of it in no time. :thumbsup:
  3. Jan 18, 2012 at 3:52 PM
    boxxed
    Denver, CO
    09 Off Road
    Ok I get that.. What about going 60 or so from D to 4 is that a bad thing to do. Should you always drive in 4 when going through the mountains? (Aside from downshifting)
  4. Jan 18, 2012 at 5:08 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I wouldn't be afraid at all to use 4 or 3 on the auto going downhill. Not that I'd leave it in that gear all the time, any time you don't need the engine braking you'd be wasting fuel.
    The truck will do darn near 70 in 2nd gear. You will not hurt it descending a hill in 3rd or 4th, although that would have to be a steep one (or a slow speed) to need 3rd.
    Biggest possible issue, snow. Careful engine braking on the slick stuff, it can cause problems, though not as much as a front wheel drive.
    edit: as for screwing up your transmission, don't shift to 1st. It likely has a speed lockout (almost all vehicles do) to prevent damage anyways.
  5. Jan 18, 2012 at 5:12 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    X2
    as long as you dont drop it into 1st at 50 you should be fine. just do what feels right
  6. Jan 18, 2012 at 5:18 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    just watch your revs if you're going to use engine braking and you'll be fine.
    Take it from a guy that lives on the largest volcano in the world.
  7. Jan 18, 2012 at 5:20 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Do not get in a hurry, take your time. Especially on the downhill, with an automatic your going to use your brakes more then a manual. You can get in trouble real fast on the downhill with a trailer pushing you from the behind.
  8. Jan 18, 2012 at 5:21 PM
    memario1214
    Colton
    Missoula, MT
    Are you talking about paved roads or dirt roads?
