Mounted 32" Spare
Discussion in 'Wheels & Tires Marketplace' started by Digiratus, May 19, 2018.
  1. May 19, 2018 at 8:36 PM
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    The wheel is a 17x8 "D" Window steelie with 4" of backspacing. The tire is a brand new, never on the ground, BFG Mud T/A. The tire size is 255/75r17. Essentially a 32x10.
    lo2hi likes this.
  2. May 19, 2018 at 8:40 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    What's your locarion
  3. May 19, 2018 at 8:41 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Conversation Piece? Oh crap, I was in Market Place...Duh!
  4. May 19, 2018 at 8:51 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Awesome spare. Would make a great tire for use
  5. May 19, 2018 at 10:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Seattle metro
  6. May 24, 2018 at 3:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
  7. Jun 1, 2018 at 2:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Still available...
  8. Jul 25, 2018 at 3:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I know someone needs a 32" spare...
