Mounted hi lift using factory bed cleats.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mh.meier, May 7, 2012.
  1. May 7, 2012 at 6:50 PM
    mh.meier
    mh.meier [OP] PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper(, color matched -Heretic Studios 20" single row light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -Front custom satoshi gille, color matched -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Dirt King stock length lowers (soon to be installed) -Sway-A-Way 2.0 rear ext travel shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I recently got some rock sliders from Avid Offroad and decided to get a hi lift. I bought the smity built 54" for 50$ from the dreaded 4 wheelparts.
    I mounted the hi lift using the factory bed cleats. Seemed like a good idea since I picked 4 more up off CL.
    Attach the bed cleat to.the rail system and drill a hole through the very top of the cleat. Put a 3/8 carriage bolt through the hole and secure it with a 3/8 nut. Then I used an old shock bushing and a washer with a 3/8 wing nut to secure the hi lift on the bolts. I used two cleats and put them om the rail behind the cab. If you have any questions let me know. It doesnt shake and looks good plus I still can use my cleats as tie down points.
  2. May 7, 2012 at 7:04 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    I like that! Seems simple and effective.
    Thanks for posting.
    David
  3. May 7, 2012 at 7:05 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Careful with that jack. Great idea for the mounts though.
  4. May 7, 2012 at 7:13 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Nice looks good man
  5. May 7, 2012 at 7:14 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    has it help up to any beating yet?
  6. May 24, 2012 at 3:05 PM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    Great idea and well fabbed. I wonder about the plastic cleats snapping but only abuse and time will tell.
  7. May 24, 2012 at 3:30 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    The.setup has now been MOAB tested and held up no problems!
  8. May 24, 2012 at 3:33 PM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    good creative work
  9. May 24, 2012 at 3:36 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Thanks man. It cost 2$ and will hold up till I get my roof basket.
  10. May 24, 2012 at 3:49 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Good idea.
    Hi-Lift tip - Open you door were you are using the lift on your sliders, too often the jack will tip and put a nice dent in your door.
  11. May 24, 2012 at 3:50 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Been there man.
