Mounted my DIY water tank!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by daohaus, Jul 24, 2017.
  1. Jul 28, 2017 at 8:27 AM
    #101
    msting22
    msting22 Well-Known Member
    Marcus
    Powder Springs, GA
    2016 Quicksand TRD Off Road
    WeatherTech - Floor Mats Black out badges General Grabber AT2 TRD Baja Rims
    I'll give it a try but I think it will just end up cutting the tap up every time I have to fill it.
    daohaus[OP] likes this.
  2. Jul 30, 2017 at 11:51 AM
    #102
    LUNCHBOX66
    LUNCHBOX66 Well-Known Member
    Eric
    2012 white tacoma prerunner
    None so far
    Amazing
  3. Jul 30, 2017 at 12:24 PM
    #103
    daohaus
    daohaus [OP] Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    I use the blue Teflon tape, it's a bit thicker and seals up
    ChiCAgoTako and msting22[QUOTED] like this.
  4. Jul 31, 2017 at 1:40 PM
    #104
    peteri
    peteri Well-Known Member
    Washington
    How do you plan on cleaning it? Thinking maybe running bleach thru it??
  5. Jul 31, 2017 at 2:19 PM
    #105
    daohaus
    Duan
    percisely, and when not in use i have the fill cap open to air it out.
    shakerhood likes this.
  6. Aug 3, 2017 at 12:32 PM
    #106
    msting22
    Marcus
    Powder Springs, GA
    That did the trick.
  7. Nov 12, 2019 at 4:19 AM
    #107
    p_chinnici
    p_chinnici Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    Anything on how they last in the winter with freezing temps? I would hate to see one leak in the bed where i sleep.
  8. Nov 12, 2019 at 10:22 AM
    #108
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Mix the water with your favorite alcohol.
  9. Nov 12, 2019 at 10:23 AM
    #109
    p_chinnici
    Pete
    South Nj
    Wow why didn’t I think of that :rofl:
  10. Apr 4, 2021 at 8:21 PM
    #110
    pokatink
    pokatink Member
    Julie
    Saint Charles, Missouri
    2009 Soft Taco Supreme
    OP: can you post a picture of the brackets you used to mount the quick fists on. Thanks
  11. Apr 4, 2021 at 8:36 PM
    #111
    mikeaesq
    mikeaesq Well-Known Member
    TRD Off-road 4x4
  12. Apr 5, 2021 at 5:51 AM
    #112
    Spanky3412
    Spanky3412 Well-Known Member
    Dave
    Northern N.J.
    2020 Cement Offroad
    Not to be a bummer but I see some DWV PVC fittings on these projects they are not made to hold pressure. I've seen the fittings blow apart under pressure you will notice the pressure rated fittings have a lot deeper sockets. You can most likely get the proper fittings in larger sizes from a local plumbing supply. Please use caution.
  13. Apr 5, 2021 at 6:55 AM
    #113
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    Vatozone:rofl:
    I know...I'm 4 years late, but I've never heard that and I live in Albuquerque NM
  14. Mar 25, 2022 at 1:25 AM
    #114
    sealren
    sealren Active Member
    whats the name of the rubber bracket you have? I couldn't find any of the rubber bracket fits 4 inch tube.
