Mounting 30 inch LED lightbar in lower valence
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrannigansLaw, Oct 28, 2021.
  1. Oct 28, 2021 at 11:18 AM
    BrannigansLaw
    BrannigansLaw [OP] Well-Known Member
    Charles
    San Diego
    04 4x4 TRD
  2. Oct 28, 2021 at 12:29 PM
    tacojim02
    tacojim02 Well-Known Member
    Puxico, Missouri
    02 dbl cab trd
    2in suspension lift
    I would say it is very doable. But you would probably have to cut the valance out a little in the back and modify the brackets. Just saying.
  3. Oct 28, 2021 at 2:08 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    I mounted a 31" in there. Fit right in behind the valence. No cutting, just took the bumper off and put it back on. I made some L brackets out of some 1 inch scrap aluminum.
    TWJLee and sonofdad like this.
  4. Oct 28, 2021 at 2:17 PM
    BrannigansLaw
    Charles
    San Diego
    04 4x4 TRD
    Nice, that looks excellent.
    From how you describe it, pretty easy mount job?
  5. Oct 28, 2021 at 2:23 PM
    SellyKlater
    Ponce Inlet, Fl
    Yea basically the frame is about 32 inches apart in the section. You might have to test fit how close to mount the light bar near the radiator. But that size Bar should fit right in between the frame.
  6. Oct 28, 2021 at 2:27 PM
    sonofdad
    sonofdad Member
    2001 Tacoma TRD Xtra Cab
    ditto what @SellyKlater did above.
    installed an LED light bar last year.
    ordered this light bar and this harness. it was 32" in width. it barely fit behind the valence ... no cutting of the plastic required.
    i had to make my own brackets as well. it wasn't super difficult and am happy how it turned out.
    some pics of the install attached.
  7. Oct 28, 2021 at 6:59 PM
    GyvesHD
    GyvesHD Well-Known Member
    Edgar
    2000 Toyota Tacoma SR5 4X4
    I had a dual row light bar tucked behind but I switched to a single row style. More light output. Don’t have pictures of the brackets I made but wasn’t hard at all
  8. Oct 28, 2021 at 7:17 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    If the brackets it comes with are too tall, cut them down and re drill the center hole. Or just make your own. The hardest part will be cleanly mounting the switch
  9. Oct 29, 2021 at 8:10 PM
    Tacomasaurus Rex
    Tacomasaurus Rex Well-Known Member
    Brian
    2003 Black Tacoma 4x4 TRD fully Automatic
    Very nice I’ll have to do that! Kind of thought it’d be interesting to mount a light in side of these triangle shaped areas on grill. However it wouldn’t gain you much light…
  10. Mar 23, 2024 at 11:07 AM
    Krugermeier
    Krugermeier Active Member
    I’m going to buy your same bar and harness. I want to ask, is there any reason I SHOULDN’T run the 378 watt option they have versus the 180 watt?
    also, when it comes to the harness, the on/off switch is a circular red one. Can I change the switch to rectangular so that it fits flush in the pre-existing dash switch mounts?
    https://www.amazon.com/dp/B073XMM3T5
