Mounting a back rack??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MMazz365, Mar 31, 2011.
  1. Mar 31, 2011 at 8:49 PM
    MMazz365
    MMazz365 [OP] Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    Im making something similar to a headache rack and i dont wanna mount it to the side rails. im looking to mount it on the plastic sides of the bed. any suggestions?
  2. Mar 31, 2011 at 8:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I suggest you don't do that .
    Why are you opposed to mounting to the rails ?
  3. Mar 31, 2011 at 9:16 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    I have a tonnahu cover. I wanna fabricate something similar to how backracks mount on dodges. They have a hole in the rails with like a metal cup in them that a bolt bolts onto
  4. Mar 31, 2011 at 9:18 PM
    OZ-T
    Peter North
    British Columbia
    There's nothing but sheet metal under the plastic bed caps
    I will find you a link with pictures
    Half a sec
  5. Mar 31, 2011 at 9:23 PM
    OZ-T
    Peter North
    British Columbia
    Can't find the thread I was looking for , i think I have some pics on my computer , I'll have a look
  6. Mar 31, 2011 at 9:25 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    Alright um how would you suggest how to mount it? Ill see if I can draw up something that'll itll look like
  7. Mar 31, 2011 at 9:39 PM
    OZ-T
    Peter North
    British Columbia
    This is what is under the plastic cap
  8. Mar 31, 2011 at 9:44 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    this is what i was looking into doing
  9. Mar 31, 2011 at 9:52 PM
    OZ-T
    Peter North
    British Columbia
    Mount it through the top of the Tonneau , or does yours sit below the bed caps ?
  10. Mar 31, 2011 at 9:55 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    Below. Its a truxedo low pro
  11. Mar 31, 2011 at 10:11 PM
    OZ-T
    Peter North
    British Columbia
    Are you gonna use it as a lumber rack or light bar ?
  12. Mar 31, 2011 at 10:12 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    Just a light bar
  13. Mar 31, 2011 at 10:14 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That's awesome. I needed that for my CB antenna project this weekend.
    So, it looks like you don't need to remove the bedrails to remove the caps?
  14. Mar 31, 2011 at 10:16 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    So, just a stupid thought here - but have you considered mounting a roof rack and using it as a light bar?
  15. Mar 31, 2011 at 10:17 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    Yeahh I just probably have its done welded and maybe mounted next week. Ill pose some pics up. I plan on mounting a CB antenna and scanner atenna to it. Maybe reverse/bed lights and offroading lights. Maybe even ems and fire dept lights too lol
  16. Mar 31, 2011 at 10:19 PM
    OZ-T
    Peter North
    British Columbia
    No , but you have to be careful with the tabs that hold the cap to the metal sides .
    Bullwinkle check out this thread for a bit more info
    http://www.tacomaworld.com/forum/showthread.php?p=1209712
  17. Mar 31, 2011 at 10:21 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Based on your diagram, I'd think about mounting to the front stake holes and trimming the bedrail covers to just skirt around the new rack.
    EDIT: and if you're going to mount an antenna to it, make sure it's got a good electrical conducting ground connection to both the bedsides.
  18. Mar 31, 2011 at 10:24 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  19. Mar 31, 2011 at 10:26 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    Yeah that's what Im hoping to try to do
  20. Mar 31, 2011 at 10:47 PM
    OZ-T
    Peter North
    British Columbia
    You will need as wide a base plate as you can fit on the underside of the rail cap otherwise the headache rack will lever back and forth and eventually cause a failure at the mounting location
