Mounting a Roll Bar to Bed
Discussion in '1st Gen. Tacomas (1995-2004)' started by BartMaster1234, May 5, 2017.
  1. May 5, 2017 at 8:08 AM
    BartMaster1234
    BartMaster1234 [OP] Well-Known Member
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I bought a roll bar to mount in my bed. Before y'all give me the lecture (I already got one for my 'grille guard' up front :D) Yeah, I know it doesn't protect against rollovers. I just like how it looks, plus it gives you tons of mounting points for bed lights, side lights, and fog lights.
    Has anyone had any experience mounting these to the bed? It's roughly 4x4 on every side, and about 3'8" tall. It mounts at the frontmost of the bed, and rear of the wheel wells. I know I'm going to have to drill into the bed. I'll prime the holes to stop rust.
    Anyone have any advice? Drilling technique, and hardware? Thanks!
    (I love Chrome, but this is a little too much. I'll be painting in black before I install it.)
    muddog67, Dalandser and ChadsPride like this.
  2. May 5, 2017 at 8:11 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Just watch where you are drilling. Po of mine must of had a roll bar. Holes are there. Good place for water to run out now. Haha
  3. May 5, 2017 at 8:12 AM
    Xbeaus
    Beau
    I'd plate it on the backside to sandwich the box between the roll bar and the plate. Not very thick metal.
  4. May 5, 2017 at 8:16 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    I think you can get Sacrete and Simpson anchors at home depot.
  5. May 5, 2017 at 8:25 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Go for it Tyler :D
    when drilling, start small and go slow.. until you've drilled to the diameter you desire.
    watch for obstructions below the bed and wheel well and make sure you don't drill into them.
    use locking fasteners: lock washers or nylock nuts
    paint first
    BartMaster1234[OP] likes this.
  6. May 5, 2017 at 8:33 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Thanks! Should I reinforce it somehow? I was thinking of using some steel under the bed and painting it.
    Dalandser likes this.
  7. May 5, 2017 at 8:35 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    What's the advantage of using that over just standard nuts and bolts?
  8. May 5, 2017 at 10:27 AM
    pray4surf
    Rick
    Oceanside, CA
    Itchyfeet is just yanking your chain :D
    At least large area washer (aka fender washers)
    Another steel plate underneath would be overkill - depends on how much abuse your going to give it. Where you penetrate the bed floor will dictate reinforcement...
  9. May 5, 2017 at 10:55 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    I like bed rollbars.
    pray4surf likes this.
  10. May 5, 2017 at 11:01 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Those are also good for mounting machine guns to.
  11. May 5, 2017 at 11:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    They use Tacomas out in Iraq, actually. The ones that were built in Fremont, I'm surprised they didn't use Hiluxes.
  12. May 5, 2017 at 11:15 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh haha. I use Simpson products for a bunch of things around the house, I wouldn't have been surprised if that was a thing.
  13. May 6, 2017 at 12:54 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Not a big deal probably, but priming won't stop rust - just help paint adhere to the surface the same way it will help water adhere to the surface if it's not top coated with paint. I'm sure you meant prime and paint when you said you'd prime the holes you drill, but figured I'd throw that out there anyway. :thumbsup:
  14. May 6, 2017 at 2:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is not a Roll Bar It is a light bar !!
  15. May 6, 2017 at 3:48 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    "Show bar".
  16. May 6, 2017 at 4:55 AM
    Indy
    Indy Master of all I survey.
    I'm surprised it's not rusty. Most things from the 80s havent held up that well.
    You won't be able to just rattlecan over the chrome, you'll need to sand welland prime or it will look like crap in pretty short order.
  17. May 6, 2017 at 12:13 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It's held up well. I went and picked it up this morning, I'll post some pics in a minute. The Chrome is in great condition but there's some surface rust on the outside, and a ton of rust on the inside. It sits way too high and it's not wide enough so I'm going to have to do some welding, cutting, and extending of the struts.
  18. May 6, 2017 at 4:35 PM
    Itchyfeet
    I disagree the ladies from the 80's are holding up really well compared to ladies from the 70's
  19. May 6, 2017 at 5:37 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I went and picked it up this morning. It's in great condition considering its age. According to the owner it came off an old 90's Chevy truck and he went out and bought a big ass 2015 Dodge RAM and it didn't exactly fit, as you can imagine.
    Lot of rust on the inside, but I'm not too worried. It sits too high and doesn't line up with the cab, plus the rear struts are not long enough to accommodate the wheel wells. I'm planning on buying 2 inch steel tube and welding some extensions to the rear struts, and cutting a couple inches off each support and re-welding the mounting pads to make it look a little better.
    I'm also going to be painting it black. I love chrome just as much as the next guy, but this is a little extra.
    Gonna have to wait a few weeks though, I don't know how to weld or have a welder yet. Lol.
    Instead of grinding or sanding the Chrome off, I'm going to have my dad strip it in an acid bath. He works at a automotive plating plant. It'll make the finished product look better once I paint it.
    (You can see the grille guard I refinished up front, and if you look closely at the second picture you can see the Delta toolbox I repainted in the background)
  20. May 6, 2017 at 8:01 PM
    Itchyfeet
    I'm not sure that I'm feeling it. The proportions just look a little odd
