Mounting amps inside the front or rear doors.
Discussion in 'Audio & Video' started by inthebed, Apr 17, 2016.
  1. Apr 17, 2016 at 1:43 AM
    inthebed
    inthebed [OP] Well-Known Member
    2010 Tacoma TRD Off-Road Prerunner
    I'm thinking this could actually work, as painful as it would be to actually get the wires into there. I don't see a downside to this... any opinions?
    Honestly I can't think of a better place to put a speaker amp if I'm using all of the rear storage space for subs.
  2. Apr 17, 2016 at 6:10 AM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    Wth?!?!?.... Please tell me what amp/amps you are using?
  3. Apr 17, 2016 at 8:27 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Can you keep these tiny amps dry? You really wanna run all those wires in & out the door (signal, power, ground, turn-on, speaker)? Will they fit (the wires through the doors and the amps in the doors)? How will you adjust the gains? Would closing the door be good for it? etc.
    DirtJumper14 likes this.
  4. May 2, 2016 at 7:37 AM
    81shark
    81shark Well-Known Member
    under the driver seat is the best place, followed by under the passenger seat
    timothom likes this.
  5. May 2, 2016 at 8:32 AM
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    I ran new speaker wires through the door jambs. It is a bitch. You definitely do not want to try running amp wiring through there.
  6. May 2, 2016 at 8:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would think the biggest issue here would be keeping them dry.
  7. May 2, 2016 at 9:09 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I would advise against it. Not only will it have a much higher chance of corrosion, but the shock of opening/closing the door would take its toll on the amp. Stick it under or behind the seat. KeepItSimpleStupid
  8. May 2, 2016 at 7:54 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    under the seats or in the centre console.
    NO on the doors
  9. May 2, 2016 at 8:00 PM
    Gusfco
    Gusfco Member
    Bad idea. Under the seat is best + there's an AC vent to cool the amp.
    I just did mine a few weeks back. Lots of room and easy to adjust.
    Aside the b*itch of running all the wires, no adjustment access, gonna get wet and amps generate HEAT.
  10. May 16, 2016 at 2:03 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    i barely found space for the component 2"x2" crossover in the doors. Good luck getting an amp in there.
