Mounting hardware for factory hitch
Discussion in 'Towing' started by 8th sin, Feb 20, 2009.
  1. Feb 20, 2009 at 6:04 PM
    8th sin
    8th sin [OP] Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    Hey everyone,
    I am going to be picking up a used factory hitch in a few days. It does not come with any mounting hardware. I searched for the specs online but didn't find anything. Does anyone know what size and how many bolts I need? I'd rather just hit the hardware store instead of the stealership. Thanks
  2. Feb 20, 2009 at 6:10 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    just go to the hardware store and get grade 8 bolts,nuts and lock washers. Should need them very long. I believe its 4 to the frame rails, and then 2 or 4 on the top of the frame on either side.
    so total i think its 8 bolts, but on the 1st gens you gotta take the bumper off. not sure about the new trucks
  3. Feb 21, 2009 at 11:56 PM
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    I just installed the factory hitch on my 05 tacoma. Each side was 8 bolts i think, then 2 on each side that go vertical, then the 2 that go thru the rear bumper to the hitch. I'll check the instructions to see the bolt sizes if they say it and i'll let you know.
  4. Feb 22, 2009 at 6:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. There is alot of bolts as the factory hitch has a reinforcment plate.
  5. Feb 22, 2009 at 8:52 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    that would be great. I checked the FSM, but it doesn't really address what bolts are used to install.
  6. Apr 23, 2009 at 5:44 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    bump...anyone?
