Mounting OME Coils to shocks
Discussion in 'Suspension' started by Alaskaflyer, Feb 9, 2009.
  1. Feb 9, 2009 at 4:30 PM
    Alaskaflyer
    Alaskaflyer [OP] My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    So I get my shocks in today and I tried to install them using my Spring Compressors (harbor freight), well I was almost to where I could install them and noticed how the compressor was bowing so I took them off and called a local shop so they could install them with their wall mounted compressor. This is going to be a long week waiting to install everything!
  2. Feb 9, 2009 at 4:36 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Smart man bringing your springs to a shop to get them installed.
  3. Feb 10, 2009 at 11:21 AM
    Sandfire
    Sandfire Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    Let me know what they charge for that, I'm going to need that done as well.
  4. Feb 10, 2009 at 11:42 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Aww shit, rent compressor not gonna do it? Got this coming up whenever my TRDs come.
  5. Feb 10, 2009 at 11:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The Springs are pretty strong. The rental compressors have caused many injurys in the past. I always recomend, if you dont have a solid wall mount compressor, pay the $20.00 or so per side, and have it done for ya. :)
  6. Feb 10, 2009 at 3:17 PM
    Alaskaflyer
    Cape Cod, MA
    I paid 20 bucks per side. Well worth it as far as I'm concerned.
  7. Feb 10, 2009 at 4:04 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OK, y'all talked me into it. Did my own on my car but they are not sprung like these nor are they as thick. Now if I can just find a convenient reputable place around the house. Beginning my search now.
    Any body forsee issues using my oem springs on the trd yellow bilsteins?
  8. Feb 10, 2009 at 4:11 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    good -- no issues with using those shocks, other than it won't ride the greatest...
  9. Feb 10, 2009 at 4:17 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It's a truck & my 03 P5 is so low that it makes me think my ass is draggin the ground & rides like a track car to a certain degree so it should be better than the toasted ass plain oems on there now. Hopin to ditch a little wandering & wheel hop on bumps. Little worse ride with more control would be worth it to me.
  10. Feb 10, 2009 at 4:19 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    I have a buddy that never returned his from some auto parts place and it works fine. What sux is that it was locked in his brothers garage when we needed to install mine. No way I was going to undo all the work we had done so we did it the old fasion way. Please don't try this if you don't have too.......
  11. Feb 10, 2009 at 4:27 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Even tho my truck isn't lifted, just standard base model prerunner? What if I go with a spacer? What size would be optimal? 2.5 with 1.5-2.0 aal out back OK?
  12. Feb 10, 2009 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  13. Feb 10, 2009 at 5:04 PM
    Alaskaflyer
    Cape Cod, MA
    If you take yours to a shop to put them together for you make sure they put them together right, I will be taking mine back tomorrow, the studs up top don't line up right with the bottom mount of the shock and they forgot to install the upper rubber shock bushing. I printed out from the service manual how to assemble them and how everything should line up. My bad for figuring a automotive repair shop would know how to put this together right, unfortunately I couldn't stay when they did the work I had to drop them off and pick them up later. Hopefully this will be my one SNAFU for this project.
  14. Feb 10, 2009 at 6:36 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OME??? I have oem plain factory black shocks right now. Are you saying that a base model factory coil on 08 v6 DC TRD yellow/blue shocks with 12k on them & no offroad time is gonna lift my truck 2.5 in the front or was that with a OME spring? How much if any would I get with plain factory coil + TRD? I really just wanted fresher better shock action. Mine seem fatigued. A 3/4 lift in front might be good without adding aal. Just want those 31s not sawing on the wheel wells, barely touches any only if wheel turned all the way.
  15. Feb 10, 2009 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No big deal if the bottom shock mount eye doesnt line up with the top plate studs. Just use a long 1/4" or long 3/8" ratchet extension to turn the bottom of the shock to line it up.
    OME = Old Man Emu. Proven off road suspension components.
  16. Feb 10, 2009 at 6:53 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    That's what I figured. I'm just hopin the TRDs aren't compressed much more than they should in the normal ride height with the oem spring.
  17. Feb 11, 2009 at 5:56 PM
    Alaskaflyer
    Cape Cod, MA
    Well, once again another TW member (me) is thanking Chris. Chris hooked me up with some info that kept my coils from being assembled incorrectly. Again, Thanks Chris, you saved me probably a couple hours of work this coming Saturday!
    Gary
  18. Feb 11, 2009 at 6:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Anytime, gary! Cant wait to see it finished. :D
  19. Feb 16, 2009 at 3:59 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    ome.
