Mounting points for oem steps 2010 DCLB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dsmithla, Jul 18, 2013.
  1. Jul 18, 2013 at 8:15 AM
    dsmithla
    dsmithla [OP] Member
    Hi guys. I just ordered some Predator Step bars for my 2010 DCLB. The bars have three brackets, all the same. On the cab of the truck, it looks like the front mounting points are significantly farther apart than the rear two sets of mounting points, meaning the front bracket won't line up with both holes.
    Have I got the wrong steps or something?
    thanks,
    D Smith.
  2. Jul 18, 2013 at 8:18 AM
    Kilo Charlie
    Kilo Charlie I have lost my way
    Iowa
    2017 Inferno Off Road
    Are you refering to the the black steps? The mounting brackets are adjustable on those
  3. Jul 18, 2013 at 8:28 AM
    dsmithla
    well the slots for the bolts are somewhat elongated, but other than that, not so much on these. I'll try and put some pictures up.
    My real question is about the spacing of the mount points on the body. Are the sets of holes all spaced the same (i.e. is the distance between the front two mounting holes the same as the distance between the middle two mounting holes and the the distance between the rear two mounting holes?). Does that make sense?
  4. Jul 18, 2013 at 8:39 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Sub'd for later. I can help but I'm not at my computer til 12ish to show you pictures.
  5. Jul 18, 2013 at 9:15 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    From the picture below, the mounting bracket at the bottom goes to the backside. The two mounting bracket up top is where the front of the truck is.
  6. Jul 18, 2013 at 12:38 PM
    dsmithla
    o.k. that's what my steps look like. All the 'plate' parts of the brackets, where the bolts go through are the same size, but check out the mounting holes in the truck. The front set are 2 to 2 1/2 times as far apart from each other as the rear two sets are.
    The pictures are of each set of mounting holes, front, mid, rear on the passenger side, of the vehicle (driver's side is just the same), with a tape measure held up next to them for scale of reference.
  7. Jul 18, 2013 at 1:12 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    Now I see what you're talking about. The front one only requires one bolt. The middle and last requires two.
  8. Jul 18, 2013 at 1:14 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
  9. Jul 18, 2013 at 1:17 PM
    dsmithla
    o.k. thanks.
  10. Jul 18, 2013 at 1:18 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    No problem. Hopefully it works out!
  11. Jul 18, 2013 at 1:18 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Looks like this brand doesn't use the same type of bracket the toyota ones do in the front. The toyota ones have a extended front bracket that utilize both bolts for mounting.
  12. Jul 18, 2013 at 1:24 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    They all come from the same company. Nfab makes them and Smittybilt just box them in their own box (or the other way around). Toyota just have them made without Nfab's logo stamped on the steps.
  13. Jul 18, 2013 at 4:08 PM
    That Dude Tim
    Elyria, OH
    Ok that might be so but then why do the "Toyota" branded ones have a different front bracket if they all come from the same supplier? I don't believe that Nfab makes the oval tube steps.
  14. Jul 18, 2013 at 4:43 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    It's not a different bracket. For some reason, Nfab decided to have two holes in their front bracket when it only requires one. Same goes for "Toyota" & Smittybilt models. OP is referring to predator step bars, not oval tube steps.
    Edit: The picture I provided is actually Toyota's Predator Step Bars.
  15. Jul 19, 2013 at 8:22 AM
    dsmithla
    Actually I got these from TRDParts4u. I thought they were Toyota branded, but I didn't ask specifically. I've been really happy with the support TRD4u has been giving me, answering dumb questions (somehow they shipped without the installation hardware or docs, but Barbara at TRD is running that down for me). Timely, decent price. Wasn't perfect, but they are making it right, so I'm not worried about it.
  16. Jul 19, 2013 at 8:29 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    If you need additional help after receiving your hardware and docs, pm me
  17. Jul 20, 2013 at 6:53 AM
    dsmithla
    I saw the instructions last night. Sure enough, it shows one bolt on the front bracket. It's even annotated to point it out. Just waiting on the bolts now. They should be here Monday.
    Thanks Everybody.
