Mounting siren speaker behind the grille
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFRNDAN, Mar 18, 2011.
  1. Mar 18, 2011 at 1:09 AM
    FFRNDAN
    FFRNDAN [OP] Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    I am looking into solutions for mounting 2 siren speakers behind the grille of my 2009 Access Cab. This is for Code 3 response for the Fire Dept I'm on. I traded my 1998 GMC Jimmy in last week, and haven't looked back! Here's a quick vid of what the Jimmy looked like last week (I kept all the lights, of course) :D:p
    http://www.youtube.com/watch?v=YHtx7HA0fqY
    I am looking for a no-holes drilled method of mounting speakers similar to this one: https://www.speedtechlights.com/product_detail.php?catid=7&id=6 The issue is, they weigh 3-5lbs. I was looking into the elusive elements mount to go along with his grille insert. Just wanted to bounce the idea off of someone before I drop $$$ on something I might end up breaking.
    Also, please keep the legality discussion to a minimum, I wouldn't do this if it was illegal. :D
  2. Mar 18, 2011 at 1:25 AM
    Zanamoe
    Zanamoe Future ruler of the world!
    Curt
    Bakersfield, CA
    09 Magnetic Grey Off-Road Only
    3" Pro Comp lift kit, Moto Metal black wheels, Pro Comp. Xtreme TA tires, Cobra CB radio with PA, custom rear light bar, rear tailgater deterrent lights, desert whip mount, tinted windows, black headlight mod and blacked fog lights, GrillCraft black mesh grill, Tacoma bed mat, extra d-ring mod, behind grill light bar, hid 700ff Hellas, blacked emblems, Maglite mount, flipped spare, fogs anytime, washable cabin air filter, AFE pro dry airfilter, Redline hood struts, led interior lights, Magnaflow muffler, 18" Stubby antenna
    you could possibly tuck them on the front clip right behind/next to the headlights. there are several holes that will allow access for your wiring and to be able to hold the 3-5 lb. speakers. i have a PA system on my truck and have my speaker tucked in the same spot and it doesnt vibrate and looks clean and professional. hope this helps and others will also chime in to help you.
    best of luck
  3. Mar 18, 2011 at 3:37 PM
    FFRNDAN
    Dan
    Edinburg, Oh
    Bump for the evening crowd
  4. Mar 18, 2011 at 7:37 PM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    i fit a federal signal dynamax ms100 speaker behind there with no holes drilled. i'll try to remember to take pictures tomorrow for you if you want. it sits directly behind the front license plate behind the opening above the valence.
  5. Mar 18, 2011 at 8:24 PM
    FFRNDAN
    Dan
    Edinburg, Oh
    That would be awesome! Thanks!
  6. Mar 19, 2011 at 11:11 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I mounted an alarm siren back there.
    Probably a lot smaller than what you're doing
