Mounting Snugtop Tonnaeu To Siderails
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sidehack, Apr 26, 2011.
  1. Apr 26, 2011 at 11:39 PM
    Sidehack
    Sidehack [OP] Well-Known Member
    Chuck
    Simi Valley
    07 DC Long Bed Sport
    Black Westin Oval Step Bar, Blacked out tail lights, ScanGuageII
    I have a Snugtop Tonnaeu that I like. What I don't like is the frame that attaches to both sides and the cab end of the bed. I miss having my side tie downs. Is there any way to mount the pistons directly to the side rails without the six foot long piece of metal? Is the side rail strong enough to handle say a one foot long piece of metal with the piston mounted on that? Has anyone done this sort of mod?
  2. Apr 27, 2011 at 10:16 AM
    Dat Soon
    Dat Soon Member
    Art
    Bakersfield CA
    PreRunner V6
    The Snug tonneau is mounted to the factory track because it's a composite bed inside instead of steel and wouldn't be strong enough. You can still mount your tie downs if you drill through the Snug aluminum rail at specific locations. The only drawback is that you won't be able to slide your tie downs in the track...but it may still work for you as intended
