Mounting TOYOTA Emblem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChamYota, Oct 20, 2011.
  1. Oct 20, 2011 at 2:00 PM
    ChamYota
    ChamYota [OP] Crash Bandicoot Or Groot, Just Depends
    Cam
    Columbia,South Cakalacky
    05 PreRunner and 2001 Turbocharged Lexus IS300
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Hello All!
    I just got this in the mail and im stoked as i can now finish the front end of my satoshi! :taco:
    The problem is I do not know how to mount it in the center. My satoshi will be done this week so I need to know now how I'm gonna mount it. Thanks in advance :)
    Front
    Back:
  2. Oct 20, 2011 at 2:03 PM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '16 4Runner Trail Barcelona Red
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    I used expoxy and its been holding fine thru winter and car washes and such.
  3. Oct 20, 2011 at 2:07 PM
    =JSG=
    =JSG= Well-Known Member
    Canada
    2017 DC TRD OR 4x4 SB
    Morimoto 2 Stroke lows, Baja designs Squadron-R Sport as fogs, Method NVs
    I painted two screws black drilled them through the mesh and put some epoxy on the back:
  4. Oct 20, 2011 at 2:09 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    what is the back of it look like? just flat? if it has a clips of some kind you could use zip ties. think ive heard of that before.
  5. Oct 20, 2011 at 2:09 PM
    ChamYota
    Cam
    Whats that? How does that mount it?
  6. Oct 20, 2011 at 2:10 PM
    ChamYota
    Cam
    It has 3 "crosshair" protrusions at the "A" the 2nd "O" and the "T"
  7. Oct 20, 2011 at 2:12 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Where can I buy one of those emblems?
  8. Oct 20, 2011 at 2:12 PM
    DTaco55
    DTaco55 Active Member
    Derek
    L.A.
    2011 TRD Sport
    Can you take a pic of the back of the emblem?
  9. Oct 20, 2011 at 2:17 PM
    65tacodude
    Wade
    Manteno, IL
    Epoxy glue. I basically filled the back side of the emblem and stuck it to the grill material. The epoxy oozzed around the metal and I put some weights on it to let it set up. Then when it dried, I turned the grill over and went over the back of it too. No fastener except tape to hold it in place while it set up. Been working fine with sub zero temps in the winter and +100 temps in the summer and car washes inbetween
  10. Oct 20, 2011 at 2:21 PM
    ChamYota
    Cam
  11. Oct 20, 2011 at 2:25 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I cut the f'r apart with a dremel and then epoxied my screws to the back (in the appropriate positions that are level, distanced, etc). Slap it on and tighten it up.
  12. Oct 20, 2011 at 2:28 PM
    ChamYota
    Cam
  13. Oct 20, 2011 at 2:51 PM
    ChamYota
    Cam
    Well i guess epoxying the back of the emblem (after cutting off the protrusions with a dremel) and slapping it in the middle(after alignment) and epoxying it again on the other side of the mesh will hold it there. We'll see.
  14. Oct 20, 2011 at 3:44 PM
    Leggo
    Newton,Ma.
    it works well that way.
  15. Oct 20, 2011 at 3:45 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    2 or 3 screws thru plastic between letters, washers & nuts on the back.
    Paint heads black. All after cutting posts of the back of the emblem.
    Another method is to wrap 2 or 3 Cable Ties thru the mesh and around the Plastic between letters.
    Or You can go overboard and do what I did.
    See Link in my Sig
    CC
  16. Feb 15, 2012 at 4:59 PM
    WVUtacoma
    WVUtacoma Well-Known Member
    Jeremy
    Morgantown
    08 SR5 Work in Progress
    BHLM WeatherTech Floor Mats Black LED Tail lights K&N Air Filter Satoshi Grille - "Toyota" Emblem Tacoma OEM seat covers AVH-3200BT Pioneer Touchscreen DVD/Blu-Tooth/Navigation System
    Just got my emblem today. I wanted to subscribe to this thread so when I begin working on an install tomorrow I can come back and have a reference point. :D
  17. Feb 15, 2012 at 7:29 PM
    SeniorSpan
    SeniorSpan Well-Known Member
    Bob
    Colorado Springs
    11 Silver 4wd TRD DC TXpro
    ChamYota,
    You have lots of options as you can see so far. You can attach the emblem as one piece, as designed, or cut it up to obtain individual letters. The individual letters allow you to adjust the layout spacing on your grille. I elected the individual letters; to date, I have found several dabs of clear RTV on each letter works pretty well. Has held up 4 wheeling through the Colorado Mts and has gone through the winter with no signs of weakening.
    Hope this help.
    Cheers
  18. Feb 15, 2012 at 7:34 PM
    ChamYota
    Cam
    For the record, I've long finished this project. :D
    Its been done since 12/26.
    I'll post up some pics i suppose.
