Mounting Wheels soon, not sure about lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by macampos50, Jul 26, 2012.
  1. Jul 26, 2012 at 5:52 PM
    macampos50
    macampos50 [OP] Well-Known Member
    mike
    san diego, ca
    new beast- 7-2012
    Bilstein 5100's all 4 corners, Drop in K&N, Interior LED, rear LED, reverse HID breaklights, turn signal LED and HID's by CSjumper2003, Cab Chop by Socalduckslayer, TC UCA's, wicked flow 13", ammo can mod, fog light mod, A little pastidip Everywhere Goals: AAL by 4WD, intake, pulleys? Spacers? maybe a power chip?
    I bought the Bilstein 5100's for all 4 corners.
    I did the max lift for the front end on the truck. I think it's a 2" lift.
    When I mount my 285/70/17 BFG's do you think the truck will be level or be too high in front or are the tires too big for the lift the shocks give me?
    Thanks, I'm half retarded.
  2. Jul 26, 2012 at 5:54 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    2.5" is the max on 5100's. If you have a stock rear then it will be high in the front but not much
  3. Jul 26, 2012 at 5:55 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    The 285's should be fine with 2.5" but you'll have to cut some plastic and most likely do a cab mount chop. Also if you have stock wheels you'll have to run spacers
  4. Jul 26, 2012 at 5:56 PM
    macampos50
    mike
    san diego, ca
    new beast- 7-2012
    I put 5100 rears on too. Will that balance me out?
  5. Jul 26, 2012 at 5:56 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    Shocks wont lift the rear, leaf springs will
  6. Jul 26, 2012 at 6:01 PM
    macampos50
    mike
    san diego, ca
    new beast- 7-2012
    dammit! I'm putting aftermarket 17's on...
    to balance the truck with adjustable from 5100's and standard 5100 in rear.
    what kind of leaf springs should I use?
    OR should I buy the 17's and get a smaller tire, like a BFG 265/XX/17?
  7. Jul 26, 2012 at 6:02 PM
    macampos50
    mike
    san diego, ca
    new beast- 7-2012
    OR should I buy the 17's and get a smaller tire, like a BFG 265/XX/17? and lower the front end one level?
  8. Jul 26, 2012 at 6:08 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    I see your from SD. Ill send you a pm. Talk to Doug. His screen name is 4wd. He does custom rear springs. You dont need to lift the back to run 285's but you will need the front lift at 2.5". If you want it level you will have to lift the back as well
  9. Jul 26, 2012 at 6:12 PM
    macampos50
    mike
    san diego, ca
    new beast- 7-2012
    thanks bud
  10. Jul 26, 2012 at 6:14 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
